Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-26-2005, 06:47 PM
JettaSteve JettaSteve is offline
Question rear window
My rear window won't go up or down with the switches, only when I use the key is in the door lock then it goes up and down. does anyone know or ran into this problem before? Thanks
Old 07-27-2005, 06:41 AM
98R/TDailyDriver's Avatar
98R/TDailyDriver 98R/TDailyDriver is offline
Send a message via AIM to 98R/TDailyDriver Send a message via MSN to 98R/TDailyDriver Send a message via Yahoo to 98R/TDailyDriver
Re: rear window
So the driver switch and the switch in the rear does not work? Just that one window? Both up AND down doesn't work with the switches?
Fuses first, then pull the drivers switch and check the connection/ continuity...
Old 07-27-2005, 07:41 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like your window regulator motor control module for that door is bad. Neither switches work but the command from the comfort system activates the window. If you remove the door pannel and tap the motor and black plastic part with a hammer slightly and see if the window works.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-27-2005, 07:48 PM
Re: rear window
Thanks, I'm new to this VW thing. I couldn't understand why the switches didn't work but the key in the door did.... Regulator huh? I will try that, thanks again.
Old 08-02-2005, 06:34 PM
Re: Re: rear window
I tapped on it and still nodda, so do I need a new motor? or can this be fixed? thanks for all the help.
