Old 07-26-2005, 05:45 PM
jbeardencars jbeardencars is offline
engine wiring
i drive a 1988 camaro with a 2.8 v6, multi port fuel injection. On the passenger side head of the motor there is a sensor on the very back and it controls the fan. what is it called and where can I get a wiring connector for it.
Old 07-26-2005, 06:48 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: engine wiring
NAPA auto parts has every miscellaneous part you will ever need.
It's called a Coolant temperature switch... not to be confused with the coolant temperature sensor which is near the thermostat housing.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
