Old 07-26-2005, 05:43 PM
kingsage83 kingsage83 is offline
idle control system malfunction
i have that problem on my 1996 eclipse spyder turbo
how do i fix that?
Old 07-26-2005, 10:20 PM
ned032002's Avatar
ned032002 ned032002 is offline
Maybe if more info was provided so help would be delivered.
First add your car to your signature including all of your mods and all of the troubleshooting techniques you have attempted. This will help greatly with helping you with your problem.
Old 07-27-2005, 01:17 PM
I Didnt Know How To Do That
I Will Post That Info , Thanx
Old 07-27-2005, 04:57 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
I think thats just when your ecu sees that your idle has gone up or down a little bit too much. Ive pulled that code a few times before.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 07-28-2005, 12:44 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: idle control system malfunction
Your keyboard seems to be capitalizing the first letter of every word, I'd get that looked at first.
Idle control malfuction DTC is a result of the ECU not being able to maintain closed loop control of idle speed. There are a ton of possible causes for that. If you search idle surge and other common idle problems you can uncover a ton of info. www.crebotech.com and www.vfaq.com are good resources for this. One of the problems I really try not to troubleshoot over the internet is idle control. It really is a complicated system.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-28-2005, 01:57 AM
joemathews's Avatar
joemathews joemathews is offline
Yeah, I'll say. My idle drops 250 rpm when I turn on my AC--not supposed to do that. I just tested the ISC (Idle Speed Controller) and it does not appear to be functional.
1996 Eagle Talon
Old 07-28-2005, 07:07 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: idle control system malfunction
Nice!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-28-2005, 09:58 AM
problem is that i bought the car from the auction.
so i dont know what she did to it.
but from the looks of it, it just seems like the previous owner
didnt take care of it at all.
my idle drops to 100 when the ac goes on.
and sometimes it idles at 1500 rpm.
and sometimes in park it fluctuates up and down.
which is scary.
Old 07-28-2005, 07:46 PM
joemathews's Avatar
Search http://www.dsmtuner.com/forums for "idle surge" or check out the http://www.vfaq.com article under the Intake section.
1996 Eagle Talon
Old 07-28-2005, 10:26 PM
Turbodog97's Avatar
Just a Neon
haha you think thats bad. When I had A/C and turned it on my idle would go from 1450-1500 down to 1000. Freekin crazy.
05 Srt4
97 Mx-5
