Old 07-26-2005, 04:59 PM
mickbench's Avatar
mickbench mickbench is offline
OK - Time to buy that compressor
OK - I've put this off enough. I have got to get that compressor. I mean, £7 for a can of air, and I can only make that last one model or one and a bit model.. I've build 5 cars, and half built one and I've used 4 full cans, and half another...
At £7 this is getting out of hand.. So, Iwata Smart Jet Pro it is.. At £250 is seems a lot now, but I've only got to build another 30 models, and then it starts to pay..!! I've got about 30 kits in storage now. I was holding out to ensure I did stick with the hobby, as I might have quit, but 7 or 8 months on and I'm still building..
Order for a compressor is just about to be sent..!! Does anyone else feel air cans are a waste of money, and you can't control them easy.. I managed to lower the PSI of them by careful use of the air can tap, and using a 1/4 full can... But what a way to get lower PSI for careful spray jobs with masking tape..
Old 07-27-2005, 02:51 AM
Lurchio's Avatar
Lurchio Lurchio is offline
Re: OK - Time to buy that compressor
Mick,
I had a long chat about compressors with a guy from Cammetts at Model Expo and it explained that it's not just about buying a compressor. Unless you have a matched airbrush it won't be very good!
I have a nice airbrush (unbranded) bought from ebay but this is poor quality and they reccoment spending another £100 on a decent airbrush as well!
I decided it just wasn't worth it - I reckon I can go a few yerars on aerosols alone and still save money! Shame but I don't have that sort of cash!
BTW, the sprint jet should be all you need, why go for the pro jet, seems a bit excessive!
Old 07-27-2005, 04:04 AM
mickbench's Avatar
Really? I have a badger 200 airbrush, and it wasn't a £100 + job. I haven't actually had a chat with anyone, I just assumed that compressors would work out cheaper in the end.
I'm not about to fork out £100 + for a new airbrush, + £250 for a compressor.. £350 is just too much money...
And I choose the smart jet pro, as it was the recommended compressor from some of the guys from this site. It was only £50 more (I think) and thought it would be a good investment.
If my badger is no good for this compressor, then I'll forget it, as I'm into the hobby, but not that much...
Old 07-27-2005, 05:39 AM
Lurchio's Avatar
Give the company a call or call Cammetts as they were very helpful.
It may well be the case that your airbrush is matched and would be suitabel but it's worth checking. I'm really not an expert I'm only going on what I was told a couple of weeks ago.
I only wanted to buy a compressor for my existing airbrush - was looking at either silver jet (£149) or sprint jet (£199 ) max as both appear adequate but was told the airbrush needs to be matched - it comes down to nozzle size etc.
Give them a call, I'd be interested in what you find out!
I've been using my airbrush more recently for mixed colours using a can and it's a pain.
Whilst it's fine for small parts I couldn't spray a body as the finish would be lumpy and bumpy.
I'd love to be able to mix and spray my own colours but can really justify spending £250 which was the min. recomneded package by Cammetts
Old 07-27-2005, 07:35 AM
mickbench's Avatar
OK - been in touch with them, and they tell me a badger 200 is not the best airbrush to use with a compressor, and not the smart jet range. They did say the power jet range works better with the cheaper airbrushes, but at that rate I might as well just buy a dual action Iwata brush at the same time, as that works out cheaper..
I thought the badger would be OK, as it was cheap, OK £49.99.. But it appears being cheap isn't going to help when you want to save in the end..
I now either continue with aircans, and battle with the PSI for evermore, or just spend the £350 and have done with it..!! The £350 bill is leaving a lump in my throat TBH, but I do want to airbrush more and more...
Old 07-27-2005, 07:41 AM
Lurchio's Avatar
I'm glad I spoke up, hope it hasn't annoyed you too much!
Give Cammetts a call, they offered me a great deal on Iwata compressor and airbrush for around £230 - 240.
can't remember the detail of the brush but it i written down at home! Let me know if you want and I'll dig it out for you!
Old 07-27-2005, 07:52 AM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
You don't NEED to spend a lot of a great compressor: With a proper regulator, even a $100 hardware store model will work well. An expensive hobby compressor will be smaller and quieter, but not necessarily better.
A good airbrush is a must, but the Badger 200 isn't junk. If it's working for you, stick with it. I know many long-time modelers who stick with basic brushes like the Paasche H and Badger 350. Unless your airbrush is really bargain-basement quality, technique is much more important.
Old 07-27-2005, 07:56 AM
Lurchio's Avatar
Certainly for me, I do a lot of modelling in the evening and a quiet compressor would be a big advantage!
Don't want to annoy the neighbours too much - they already have to put up with constant can rattling and extraction noises!
Old 07-27-2005, 07:57 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Personally, I'll never get into this hobby so much tyhat I pay that sort of money. I don't use the airbrush I have all that often. I mainly use spray cans and only just use my airbrush for seats, dashboards & door panels, after that it's brushes.
The results I get are good enough for me and my airbrush cost.......wait for it......£15!! (including a can of air!!)
Think how many models you could buy for £350
Old 07-27-2005, 08:11 AM
Lurchio's Avatar
I must admit that I ony use my airbrush for special mixes (like the exhaust on R34 currently building) and for STi badges on Subaru, interiors that sort of thing.
Most things I will try and stick to cans but Tamiya cans at £4 each are crazy money when they last 5 mins! (Saying that I have a whole drawer full of them!)
I'd love to mix up some body colours, I've had some great ideas for colour combinations but that is when you really need a decent brush and compressor to ensure a good finish!
Old 07-27-2005, 08:58 AM
g00eY's Avatar
g00eY g00eY is offline
i dunno how well they work, but you could try getting a... maybe 6 gallon compressor from a hardware store. 6 gallons won't be too much. i have a i think 25 gallon compressor, but haven't been able to test it out yet cuz i don't have an airbrush that fits the thread of the compressor hose(cuz Testors is stupid in that way).
Old 07-27-2005, 10:13 AM
mickbench's Avatar
OK, I’ve had some information sent to me as to why they say my Badger is a problem with smaller /cheaper compressors. They say the single action brushes draw a lot of pressure, and the smart jet and sprint jet etc work fine with the badger, until you use a larger head to spray larger areas..
Means that using my badger with a large head for bodies would be out, unless I brought a more powerful compressor. Great…!!
They have recommended for all purpose model building, including small and large area paint application the following –
Iwata Eclipse BCS airbrush
Iwata Sprint Jet Compressor
They will include a braided hose, all adaptors, two bottles for the air brush and a medium and large head. Allowing for fine detail work, and large area spraying.
Including delivery they will take 20% of the airbrush, and this will cost me £290.00… I’m going to have to think about this, as TBH £250 was a lot, but the price is creeping up, and the compressor spec has now gone down.. Anyone use a sprint jet? They fully recommended it as an ideal model airbrush compressor..
Thanks
Oh – and don’t worry Lurchio, glad you said something, or I could have got a compressor that doesn’t work.
Old 07-27-2005, 10:24 AM
Lurchio's Avatar
People like Hiroboy have recomended the sprint jet before - I believe it is ideal.
There is also the new silver jet which is 50 quid cheaper but less flexible!
I feel exactly the same as you, was going to really push the boat out and spend 200 on the sprint jet but when I found out I would have to buy another airbrush as well I had to rethink!
Still rethinking at the moment!
Maybe I'll wait and see what you finally decide and then maybe follow!
It's a lot of cash though!
I know we both started modelling at the same time. I'm not sure about you but I've spent ridiculous amounts of money on this hobby already - I feel like I've single handedly kept paypal in business (I expect many others feel the same).
And the time it consumes, I've started to ignore phone calls as they are likely to keep me away, last night a knock at the door was ignored as I was poised with a brake caliper and Brembo decal - I wonder who that actually was!
Obsession eh!
Old 07-27-2005, 10:49 AM
mickbench's Avatar
I know what you mean.. It has gone from "I will" buy a compressor to a "hmm, perhaps I better think about this some more"...
I don't know now.. Perhaps I might wait another few months... Struggle on with the cans, as always. Cost is getting a bit high as you correctly said..
And I NEVER answer my phone. Not even my mobile.. When I'm at home, as I live on my own, I love it.. Phone gets turned off, and I hardly ever answer the door... It's a brave man who knocks on my door.. My dog is trained to bark at the door, and my puppy is learning to bark at the door as well..
Old 07-27-2005, 10:55 AM
99civichic's Avatar
99civichic 99civichic is offline
Send a message via AIM to 99civichic
We are definately budget modellers. We use a Craftsman 3-gal "hardware store" special that Will picked up for about $70 USD. It's very quiet, fills up in less than a minute, and holds pressure through two cars at 3-5 coats each; we've tested. It was a wonderful investment, and we have never regretted opting for an actual air compressor as opposed to a hobby compressor. Plus, you can use it to air the tires on your 1:1 if you need to!
**edit** here's what we have:
http://www.sears.com/sr/javasr/produ...id=00915310000
*Lady Modeler*
Hers:
2000 Mustang GT - Bright Atlantic Blue
1999 Honda Civic - Milano Red
His:
1999 Camaro SS - Hugger Orange
1969 Camaro w/ LT1/T56 Swap - Hugger Orange
