Old 07-26-2005, 03:58 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
OBD-0 Dizzy question.
I am running a 90 teg dizzy (OBD-0) on my b20b and i wanted to double check the firing order. Last time i checked it was like this:
if u are facing the dizzy cap from pass. side of car
left bottom = #1
directly to the right = #2
left top = #3
directly to right = #4
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 07-26-2005, 07:23 PM
Smoghog Smoghog is offline
Re: OBD-0 Dizzy question.
left bottom = #1
left top = #3
Going clockwise you firing order is 1 - 3 - 4 - 2 So you are correct.
What dizzy are you running? I am double checking my dizzy because I can't get my timing right. (Thesilentchamber) and I thought it was a
tooth off on the timing belt @22deg. and it was so I fixed that. Now I
am running @14degs max. I noticed there is two dizzys for the 88 crx Si
at least that is what the parts places say. Can you check for a number like ... TD-02U on your dizzy or if anyone has a list of dizzys for the d16a6 I would appreciate it.
Thanks in advance
SH
Old 07-27-2005, 10:06 PM
g-ride-si's Avatar
g-ride-si g-ride-si is offline
on my a6 it is...td 02u
Old 07-28-2005, 11:12 AM
i am running a TD-23U. Its out of a 91 integra.
°Sä®GëNTö69°
Old 07-29-2005, 10:29 PM
g-ride-si's Avatar
so can i put the civic td 02u in my ls motor? one of the teeth are broke off on my teg dizzy
G-RiDE-SI
Old 07-29-2005, 10:32 PM
i dont know if u can use the same dizzy i would say no. the old dizzy i had had a broken tooth too and it was fine...
°Sä®GëNTö69°
Old 07-29-2005, 11:04 PM
g-ride-si's Avatar
ya it works i just wanted to see if i could use my other one but now that i really look at it the d16 dizzy has a longer shaft so i guess not oh well
G-RiDE-SI
Old 08-02-2005, 04:10 PM
Re: Re: OBD-0 Dizzy question.
\Thanks G
So is your si from (Susuka?) Japan? Mine is. Just wondering about the TD-05u, And if it would matter where the car is made or?????
I pulled off the cover and rechecked the cam timing it's right on.
So then I checked for the real TDC (pulled the #1 plug) and the timing cover/timing pointer has shifted about an 1/8" so I am at 18 now but the dizzy is still turned all the way.
At least it will pass smog.
Please let me know if anyone can find the info on those numbers
Thx again
SH
PS. sorry so late I was at NHRA @ infinion this weekend
