Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-26-2005, 12:23 PM
KRZYBOY00 KRZYBOY00 is offline
Ac Makes Noise
I Have A 85 Cutlass Supreme. I Had The Ac Recharged And When I Turn The Ac On, The Compressor Clicks On For A Second TheN Clicks Again And It Keeps On Doing That. I HeaRd That I Might Have Something Stuck In One Of The Lines, But I Cleared Out The Orfis?? Tube. And It Still DOES THE SAME THING . Is There Anything Else I Can Do Or What I Should Do To Fix It. Thanks
Old 07-26-2005, 03:44 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Ac Makes Noise
It sounds like the AC recharge has leaked out. The shrader valve may have a leak in it. The constant cycling indicates that the AC is low on refrigerant and is constantly cycling.
Old 07-26-2005, 05:28 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Ac Makes Noise
I agree with "Pops", you have to fix your leak.
What is your low side pressure? Did you pull a vacuum after cleaning your orifice tube? Air and refrigerant don't work together, the air doesn't compress back to a liquid in a car system like a refrigerant and the pressure will build until you start setting off the high pressure cutoff switch and the compressor will cycle.
NOW for the legalities...you have to have the system properly evacuated by a certified AC repair facility before making any repairs to be sure no refrigerant gasses escape into the atmosphere and the gasses not reintroduced until repairs are made.
