Old 07-26-2005, 10:19 AM
triplethreat triplethreat is offline
Womp, Womp, Womp sound
I'm getting this sound at 35mph and up along with a slight vibration it is the worst at 35-40 mph. I just bought this car as a certified used it is an '04 GT. I think i read on here that it is probably wheel bearings and i also read that it is like $500 a side to replace. My question is shouldn't this be covered under the factory warranty the car only has 24k miles on it. any ideas
Dan
Old 07-26-2005, 10:25 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Womp, Womp, Womp sound
Dan
Best thing to do is contact your local Pontiac dealer(s). The intial GM factory warranty is bumper to bumper meaning all defects/problems are covered. Since its a GM certified used car and you only have 24K miles, they should honor the warranty. Good luck!
Thrasher CAI, DHP v1.0 PCM,
3.25 SC pulley, CAIT GMAF, Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 TB,
TB spacer, MSD 8.5mm wires, Autolite 104s,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
Timeslip 08/12/06
AF Community Guidelines
Old 07-26-2005, 10:27 AM
jimmytroanoke jimmytroanoke is offline
Dan
could be struts, bearings, or a broken belt in a tire. Take it in, it should be covered. If it is a broken belt in a tire, and you just bought it that should be part of the certified inspection. You may have to buy a tire for the other side tho, as you have to run them in matched pairs or you will screw up your diff.
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 07-26-2005, 10:35 AM
Thanks for the quick responses. I have to take it in next week to get the key fob programed and i'll have them take a look at it
Dan
Old 07-26-2005, 12:23 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
by your description, it sounds like a bad tire, if it's a dull thud womp womp womp. Hubs will usually be a more metallic sound. Unless you hit a mean pothole, 24k is WAY too early to have a hub fail.
Old 07-26-2005, 02:43 PM
i'll pay attention to it on the way home from work today just to make sure i'm description is correct.
Dan
Old 07-26-2005, 03:36 PM
GTP Dad GTP Dad is offline
Pontiac Guy
I would bet you will find that there is a bad tire on the vehicle. Probably a broken belt in the tire. As everyone else has said the certified warranty should cover any problems with the vehicle.
Old 07-26-2005, 07:41 PM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
just to be sure check your brake rotors if they are warped that may be a potential cause?!
My Fleet 2000 F-150, 2012 Chevy Impala LTZ
Old 07-28-2005, 10:09 AM
GPFred GPFred is offline
If you know what side its coming from, you could jack it up and rotate the tire. You should either be able to see a ridge or feel the ridge on the tread of the tire if ist a broken belt. Good luck.
Old 07-29-2005, 07:38 AM
I have an appointment with the dealer on Monday so I'm gonna have them take a look at it. Other that this problem I really love this car. Athough switching between it and my F-250 takes some getting used to. I'll update you guys when the dealer finds out what the problem is.
Dan
