Old 07-26-2005, 09:58 AM
3000ridah 3000ridah is offline
starting problems
about a couple weeks ago my car started to have a lil problem. When i would turn the key over it would just click ( radio ect would come on) i have to do this about 3-4 times and then it will actually go to the starter and turn the engine over. does this have anything to do with the seleniod? please help!!!
Old 07-26-2005, 05:12 PM
Hotshot8792 Hotshot8792 is offline
hmm, i would think that there might be something wrong with the starter if its having trouble engaging.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-26-2005, 07:53 PM
davecolt davecolt is offline
Re: starting problems
I had the same thing a few months ago... thought it was electrical at first but it all went away when I replaced the solenoid and haven't had a problem since.
Old 07-26-2005, 08:47 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
If it's clicking that means the soleniod is working usually. Sounds more like the starter motor is wearing out.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 07-26-2005, 09:24 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
before you go replacing the starter (or even rebuilding it), check to make sure your battery is good. take it to auto zone, o'reilly's, or whatever chain auto store is in your area--they should test your battery for free.
reason being, the starter on my dad's car (96 camry) was doing the same things. i checked the battery and it was putting out 12.8 volts or something close to that...so that number sounded good to me. but AFTER wire-hunting for a f#%*@& 'ballast resistor' (i was told that was what was wrong since i 'knew' the battery was good) and AFTER REBUILDING the starter.... it turned out just to be a bad battery. but the battery was less than 6 months old.
so IF its your battery, make sure to get a GOOD battery (Duralast, Optima, Interstate).
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-26-2005, 09:43 PM
Re: Re: starting problems
I replaced my battery... and alternator (funny how things seem to all go out at once). after all that I still had the issue with the starter not kicking in till 3 or 4 tries.
Old 07-27-2005, 12:04 AM
unicyclemidget11 unicyclemidget11 is offline
i had same problem kind of. it eventually took like a million tries to get it to start. found a loose wire going to the starter. made me happy getting 200dollars back for starter that i bought.
