Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-26-2005, 08:30 AM
Kingkrikkit Kingkrikkit is offline
$ Brake Jobs, Need Help PLEASE
I have a 96 4Runner SR5 which I bought in 2001 with only 20k on it and it was in beautiful condition. About a year after I bought it the brakes started vibrating violently. I assumed the rotors had warped for some reason so I had a brake job. Since then, witout fail, my rotors have warped and need new rotors and new pads every 6 months (except once, where we put on heavy duty rotors, they lasted 9 mos). eEverything has been checked, the calipers are fine and the lines are clear, I dont ride my brakes at all and im not a "left foot braker". Toyota has said that theres no design issue. Can anyone help? My mechanic is at a total loss and I cant afford a $300 brake job every 6 mos.
Old 07-27-2005, 08:22 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Over torqued lug nuts can cause rotor warping.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 07-27-2005, 08:31 AM
Re: $ Brake Jobs, Need Help PLEASE
I have heard that and asked my mechanic, of course he said they do it right... I guess I have to trust him, or else pick up a torque wrench of my own. I have actually looked into some performance rotors, vented, etc. Ive heard good thing about a company called Power Slot and they make a model for my truck so I may give that a try. Of course I also assume park of the problem is all the stop and go of all the traffic.
Old 07-27-2005, 10:29 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
No, you don't need special parts, you need to solve the problem you have with rotor life. I would take it to a dealer and have them thouroghly check out the braking system, including proportioning valves, master cylinder, calipers, etc. I bet something is applying some pressure to the front brakes (or the wheel cylinders in the calipers are sticking) all the time and they are overheating. Check it out. See if the wheels (not the rotors) are really hot after you're done driving. Rotors don't warp if they are not overheated and the wheels mounted correctly.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
