Old 07-26-2005, 03:02 AM
welshman welshman is offline
tamiya porsche carerra GT problem
is anyone having difficulty with the exhaust section on their 1/24th Tamiya porsche carrera GT model?
nearly finished the engine build section but have come across a problem. As you see from the pics below the manual says that the back box will slot onto the main exhausts, but the reality is that there is a gap between them when mounted to the the main chassis. There is no part information to say that there should be a part to join these two together so how am I going to get around this problem. I am stuck now til I sort out this problem
Is anyone else having this difficulty or is it just me?
please help
tony
http://-tony-jones.fotopic.net/c629726.html
Old 07-26-2005, 03:59 AM
A_C A_C is offline
From your pic, it seems that the engine block is not placed correctly. The engine block should be moved a bit backward (or towards the rear end). You may notice it when trying to fit in the rear shaft.
Cheers,
AC
Old 07-26-2005, 10:01 AM
agamo's Avatar
agamo agamo is offline
Send a message via ICQ to agamo Send a message via MSN to agamo Send a message via Skype™ to agamo
Yes, I see the same problem, the engine is sitting forwards, check the engine-chassis assembly again, use the rear axle and the rear spindles as a reference, I already built this kit, and had no trouble at all, check mine:
Hope this helps.
Regards
Happy modeling!
Ramon Garcia
Puebla, Mexico
Old 07-27-2005, 07:52 AM
thanks
thanks for the info guys will sort it out later
tony
Old 07-27-2005, 09:08 AM
Junhao's Avatar
Junhao Junhao is offline
Send a message via ICQ to Junhao Send a message via MSN to Junhao
Re: tamiya porsche carerra GT problem
There shouldn't be a problem with the exhaust. The only problem is the snap on windshield.
Home of the Supercars:
