Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-25-2005, 11:41 PM
Berserker33 Berserker33 is offline
Send a message via ICQ to Berserker33 Send a message via AIM to Berserker33 Send a message via MSN to Berserker33 Send a message via Yahoo to Berserker33
Exclamation 98 Eclipse GST missfire problems
Hello all....i have recently purchased a 98 Eclipse GST with 88,000 miles, when i test drove it i noticed it missfired just a bit, i figured it was something minor....bad spark plugs was my immediate thought, it had a great price so i decided to drive it home that day. I got about an hour away from the dealership onto the highway....and the problem got worse....seemed to miss more frequently and also seemed more rough. I was curious as to see what people on here thought before i jumped to any conclusions....i was told possibly it was some sort of sensor problem or fuel injector, if i could get any input it would be greatly appriciated ....thanks a bunch guys. =D
Old 07-26-2005, 02:03 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Why not just pull the plugs and check them out to begin with. That way you eliminate the obvious answer and we can help you after that.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-26-2005, 07:19 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 98 Eclipse GST missfire problems
Plugs are cheap, go pick up some NGK BPR7ES and slap them in.
Also take a look at your wires, they are liable to be as old as the car. Might want to replace them also.
Deal with the cheap stuff first.
Do you have a RM CEL?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-26-2005, 03:09 PM
well
well i found out it had a cracked head or head gasket.....just great....anyone know what the price to fix that is? i know its outrageous but could anyone give me an idea?
Old 07-26-2005, 09:15 PM
viet_boiiiii's Avatar
viet_boiiiii viet_boiiiii is offline
Send a message via AIM to viet_boiiiii
If it was from the dealershit u should bring it back and get a full repair job or your money back.
new 2006 Scion tC - 5spd
-magnaflow catback
http://www.cardomain.com/ride/2088489
~~~R.I.P (7-2-05)~~~
1998 Eclipse Gst - 5 spd
Old 07-29-2005, 12:32 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Hopefully th dealer will take care of the problem, if not it's gonna be really expensive, especially if you need a new head.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-04-2005, 03:14 PM
ted_ex's Avatar
ted_ex ted_ex is offline
It is unlawful in most states for a dealer to sell a car with a problem. I'm not sure if its a federal law but it's referred to as a lemon law. If the car had the problem when you bought it and the dealer didn't disclose the problem, they could be liable. Of course they can always say that they didn't know about it. If it's a reputable dealer they should take care of you.
tedX
I'm>everything
