Old 07-25-2005, 11:14 PM
IROC Z 1988 IROC Z 1988 is offline
Switching gear problem
When I'm stopped at an intersection and then I go and my gears shift really quick sometimes I'm in third gear before I leave the intersction at 35 mph. Is their a way to change the gear ratios and make the gears stay longer before switching. any help would be nice. It doesn't switch fast if I gun it of course.
Old 07-26-2005, 11:12 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Switching gear problem
im guessing its an automatic, only way i know of to make the gear shifts take longer is to put shorter rear gears in it, like 2.73 gears. The automatic is designed to shift when its supposed to, to i wouldnt worry about it.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-26-2005, 02:11 PM
tcfco2005 tcfco2005 is offline
well you could mess with the tv cable and it will make it shift harder and at a higher point, if thats what you are looking for...but i dont know how good that is for your tranny.
1991 RS
305 T.B.I.
700-R4
Old 07-26-2005, 07:59 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
nope and nope. Using/Adjusting the TV cable can/will cause severe damage to the trans. That cable is used for setting line pressure off idle and not for shift points.
Shorter rear end gears will cause a significant loss of low end torque and speed/power.
The governor (in the trans) sets the shift points in the 700r4 transmission. you can add/remove/change the springs in order to change the shift points. stiffer springs delay the shifts, lighter springs make it shift quicker. Also removing (one or both of the) springs will make it shift quicker. It may have popped out, or someone may have removed/lost it.
the governor is behind a rounded cover on the driver side rear of the transmission. it is the rounded cover at the rearmost of the transmission. the cover pops out by prying it with a screwdriver. Easy install. go here http://transmissionhead.com/ and look at part #43.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-26-2005, 11:15 PM
89IROC&RS's Avatar
ah ha, someone who knows what they are talking about.
Old 07-26-2005, 11:38 PM
well noticed i put "but i dont know how good that is for your tranny", and thats why i put that, cause i didnt know.
1991 RS
305 T.B.I.
700-R4
Old 07-27-2005, 12:26 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
get a PROM burned and change the shift points and properties. (When I just got my tuning done I had allt aht reprogrammed, I don't see why a 3rd gen wouldn't be able to either)
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 07-27-2005, 12:56 AM
DaMoNe6969's Avatar
DaMoNe6969 DaMoNe6969 is offline
check your tranny fluid.. is it clean and at the proper level? 3rd gear at 35mph isnt unreasonable.. as long as the TV cable is adjusted properly, your tranny will shift at the optimum points for efficiency, (which is a good thing with the price of fuel) except at WOT of course ..
No, you cannot get a prom burned to change shift points.. the 700R4 is Not electronic, therefor Not programable by any means..
If your looking for a little more holding power, and snappier shifts.. Look at installing a corvette 1-2 servo (about 20 bucks) OR a street shift kit..
if you want shifts that are fast and hard, and a little farther down the rpm line, install both the servo and shift kit..
btw.. make sure your starting out with a good strong tranny before you start modding it.. burnt or missing tranny fluid could indicate a problem within the tranny These mods also cause added stress on your rear end and your neck..
1991 Camaro Z28
Old 07-27-2005, 01:24 AM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
a good band m strip kit will help u it will make it asnappier shift and save your clutches in the tranny too and the good kit can be ordered from advace for 69 bucks and takes about a hour to put in and it easy if you can read but of course you will have to buy fluid and might as well buy a filter kit
Old 07-27-2005, 11:02 AM
thanks.
personally I would like the quicker part throttle shifts. Your gas mileage will be a little better because of it... especially if you do a lot of stop ang go driving. I was thinking about making mine shift just like yours is.
it would be annoying if you didn't have enough low end power and it made your engine bog down all the time, though.
Old 07-27-2005, 12:46 PM
can some one post up what thier 700r4 shift points are so i can make sure mine are accurate. i had to adjust the tv cable when i put on my tbi spacer.
1991 RS
305 T.B.I.
700-R4
Old 07-27-2005, 11:21 PM
they are different compared to the gears in the rear end
Old 07-28-2005, 01:01 AM
how to adjust the TV cable and approximate shift points are listed here.... http://www.transmissioncenter.net/subject.htm
Old 07-28-2005, 01:20 AM
but if cables are stretched from age it helps to know the shift points to keep it right the setting of the cable might be altered and fish weights work to fix that
Old 07-29-2005, 11:00 PM
Re: Re: Switching gear problem
thank u all for the advice I will look into all that and 89 sorry to hear u leaving whis u could sray longer cause u might help me later
