| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
no oil pressure now car wont start
94 eclipse gs car's idle would drop below 1000 rpms then when i gave it gas it go back up also when it droped, the oil light would come on/pressure oil pressure gauge would fall so now the car wont start it turns but no start any help? thanks
Was it smoking? Is it leaking any oil? Check compression.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
Re: no oil pressure now car wont start
check ur oil level.
Re: Re: no oil pressure now car wont start
DSM geek |
if the car does idle between 50 and 300 rpm the oil light will come on. i would say the stalling issue is something other than oil level or pressure.
hey you try checking your oil pressure switch?If the pc sense that you dont have oil pressure on start up it will die-or not start at all.check that hope it helps.
