Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 07-25-2005, 11:04 PM
kulkan kulkan is offline
electronic speedometor faded
I'm considering picking up another used '91 aero. This one has the electronic speedo. . It is very faint and hardly discernable.
Does anyone know anything about this condition and its remedy?
TIA
Kulkan
Old 08-14-2005, 01:06 AM
Ima Ludite Ima Ludite is offline
Re: electronic speedometor faded
You have a burned out light bulb behind the cluster
Old 08-21-2005, 05:00 PM
Jplayer Jplayer is offline
Send a message via MSN to Jplayer
actually i don't think it's a bulb problem since the aerostar with the electronic display is a led type display.
first off i would check the dimmer circuit that controls the dash brightness on the headlight switch.
If thats not it then you have a dash circuit problem related to that circuit in the dash itself.
i'm sure if you do a little searching you can find a wiring diag for that model yr. If not then a store bought manual might such as chiltons or one of those.
I'll chk and see if i can come up with something but i'm sure you could too after searching
Laterz,
Jplayer
___________
Have your ever had a dream that you were so sure was real? What if you were unable to wake from that dream? How would you know the difference between the dream world and the real world? It's the world thats been pulled over your eyes to blind you from the truth...
Old 08-21-2005, 11:24 PM
I have had the E-cluster since 1990 and I have to replace the bulb behind the speedo every two years and it's always the same bulb just a normal CLB 194 peanut bulb.
When the bulb goes out, you can just see the numbers in the background and tell that the speedo is working, but you cannot tell just what it is reading because the numbers are too faint.
TTFN
Old 08-27-2005, 06:42 PM
Re: Re: electronic speedometor faded
TTFN
oops, my bad then.
I wasn't paying attention to the year you mentioned.
sorry bud
if the same bulb keeps burning out what condition is the bulb socket in? Does it fit fairly tight? or does it fit loosely?
Maybe if you check around you can find another bulb that is slightly higher in volt rating or a tid bit lower in watt rating....it won't be quite as bright but it may last longer.
Just food for thought
Laterz,
Jplayer
___________
Old 08-28-2005, 07:01 PM
walkingtall walkingtall is offline
where can i find a horn relay on my aerostar
Old 08-28-2005, 07:03 PM
horn on my aerostar makes a clicking sound
Old 08-28-2005, 08:17 PM
ehhh...not to sound like a smartallic but go to where that clicking sound is and you'll find your horn relay if the sound is comming from under the dash or somewhere other than the horn itself. If the horn itself is clicking then check voltages and make sure it's getting 12v. If not then repair the circuit. If you get 12v then replace the horn
But if the clicking sound is in fact the relay? just look for where the sound is comming from....usually they are under the hood on the drivers side fender area. Possibly under the dash somewhere on the drivers side near the fuse panel....possibly ON the fuse panel.
Laterz,
Jplayer
___________
Old 08-29-2005, 06:54 PM
Thanks jplayer i now have my horn fixed there was a short in the wiring
