Old 07-25-2005, 10:01 PM
s2pidluv4u s2pidluv4u is offline
vacuum hose line intake
...k guys i jus installed my injen intake...i was wondering what does the vacuum hose do...its the little hose u put in front of the throttle body ya the other small hose in the intake i think its called that...anywaz when i was on the freeway and floored it i kinda get this lag so i exit ASAP and went back home...what i found out i kinda cut the vacuum hose 2 short causing it 2 bend so no air will go through the hose...after i replaced it...i went back on the freeway and it runs fine...so i think the vacuume hose resolve my problem?...what does it realli do?...thanks...
Old 07-25-2005, 11:21 PM
Hotshot8792 Hotshot8792 is offline
Re: vacuum hose line intake
well, i will need a little bit more details, but until then, i will make assumptions
I am assuming you have an N/A, and you just bought an intake system that comes with an intake filter and an intake pipe, in which they included vacuum hose with it and you have no idea where the vacuum hose connects. Well, if this is the case the vacuum hose connects on the nipple of the intake pipe (like you said before the throttle body) and it goes to the rear valve cover.
If my assumptions is not right, please give me a little bit more detail such as what model 3/S you drive so i can help you.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 07-26-2005, 12:31 AM
hot shot...i gotta 1995 3kgt auto...jus wondering i already kno where 2 install it...my question was i was wondering what does the vacuum hose do...anywaz when i was on the freeway and floored it i kinda get this lag so i exit ASAP and went back home...what i found out i kinda cut the vacuum hose 2 short causing it 2 bend so no air will go through the hose...after i replaced the hose it...i went back on the freeway and it runs fine...so i think the vacuume hose resolve my problem?...what does it realli do?...thanks...
Old 07-26-2005, 01:21 AM
Igovert500's Avatar
blue + red light magnet
Depends where it runs to...and I don't have an NA, and can't find an NA vacuum hose diagram online anywhere, so I'm not the one that will be able to tell you.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-26-2005, 11:15 AM
StealthModifier StealthModifier is offline
yea, that should of fixed ur problem. thats kinda like taking any other vacuum hose off the motor, its gonna run really bad.
Old 07-26-2005, 05:14 PM
Re: Re: vacuum hose line intake
ohh ok, that vacuum hose allows the rear heads to breathe back into the intake, which is why you will find a little bit of oil in your intake pipes after a while.
Igovert- its the same hose that hooks up to your intake T-pipe
Old 07-26-2005, 07:56 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: Re: vacuum hose line intake
so is this why some people like to put an oil catch can here? would they put it on this line? or would some kind of filter suffice?
how does this differ from a PCV? where does the PCV hose go to from the valve cover?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-27-2005, 08:29 PM
Re: Re: Re: Re: vacuum hose line intake
yes, a lot of people put an oil catch can there to prevent oil from coming back into the intake. The vacuum/air goes through the catch tank from the rear valve cover back into the intake (there are two hoses coming off the catch tank). Another alternative is using breather filters if you dont want to hastle with a catch tank, just make sure you plug up your intake pipe.
The PCV valve in general allows the crankcase to remain under constant vacuum, even when a TT is under WOT. This basically keeps air out of the upper part of the heads because thats where the oil circulates. Failure to do so could cause air to seek down under the block.
Old 07-28-2005, 12:49 AM
...cool i was wondering what those lil air breathers do...cuz i was at pep boys what the heck is this...so basically is this like a mini intake filter...i mite install 1...haha...how good is it instead of using the vacuum hose instead...
