Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-25-2005, 08:33 PM
jrmontg jrmontg is offline
Brake Problem
I have a 97 Jeep Grand Cherokee Lim 4x4
when I go to stop I feel a grinding when I hit 0-5 mph. It is like I have to push the brake a little further in to get it to stop.
Has anyone experienced this?
Old 07-26-2005, 09:58 AM
JDPascal JDPascal is offline
Re: Brake Problem
Welcom to AF jrmontg
What is the brake repair history??
When the brakes are cool, reach in where you can feel the rotor surface (inside and outside) to see if the surface is scored by worn pads.
If not scored, then it is likely a friction change in the pad/rotor due to heat or contamination.
Pull al 4 wheels and visually inspect the brakes for wear and "rocks or pebbles". Some times a stone gets stuck in the rotor/caliper.
Could also be the abs activating. Are you familiar with ABS operation?? The chatter of the abs sounds like a kind of grinding and the pedal will "travel" further while it activates......
JD
Old 07-28-2005, 09:54 PM
I am thinking that maybe it might be a abs sensor. It does seem like the abs is kicking on when I try to start. I just inspected the toner ring (I think that is the name, it is a round gear with teeth) and it looks in good shape. All the brakes were replaced back in may so that could not be it.
Wonder how much the sensors are and wonder if they are easy to replace.
Old 07-29-2005, 10:02 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: Brake Problem
the sensors probably just needs cleaned, sensor and ring gear.
