Old 07-25-2005, 05:50 PM
holyniht holyniht is offline
Unhappy Reverse Lights
I did a search and didnt come up with anything concrete. When i throw my car in reverse the reverse lights dont come on. I checked the fuse and the bulbs and everything looks alrgiht. Correct me if im wrong, the revese light fuse is labeled "back up light". I have a 94 Civic DX sedan. Thanx
Old 07-25-2005, 06:19 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Reverse Lights
yep, could be a relay. how did you check the bulbs? id put the reverse one in the brake light socket and see if they work that way, because sometimes its hard to see if a bulb is blown just by looking at them
Old 07-29-2005, 05:10 PM
D16Z6_turbo D16Z6_turbo is offline
Re: Reverse Lights
It might be the reverse light switch. I believe it's located under the shifter. Open the center console up and you should see it.
Old 10-16-2005, 03:44 PM
Re: Reverse Lights
sorry about the delay but i finally got around 2 checking it, but i didnt see any reverse light switch under the shifter, by center console i assume ur referring to the plastics thats consist of the emergency break, cup holder, rear astray? i did see a wire running but those where for the emergency break light.
