Old 07-25-2005, 04:48 PM
ulremember ulremember is offline
1990 Caravan Torque Converters
Are there two different converters that a Caravan uses. I have accomplished installing the tranny, but now I notice that the flywheel and the converter bolt holes do not line up. I purchased a used tranny from the wrecking yard along with the converter. It looks like the alignment is about 1/8th of an inch off. B4 I put the "old" converter in, I want some "professional" advice and education.
Thank you in advance.
Chuck aka ulremember
Old 07-26-2005, 03:37 PM
waltham41 waltham41 is offline
Did you get the torque converter off of a same year vehicle with the same size motor?
Call your local parts store and they can tell you if the parts will interchange by looking up the year and size motors that you are dealing with and also if there were more than one converter listed for your year vehicle if you did get the used tranny and converter out of the same motor and year as yours.
