Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 07-25-2005, 04:31 PM
zengel442 zengel442 is offline
95 - Engine turns - doesn't Start
I have a 95 Aurora that turns over well, but does not fire up. Replaced the fuel pump and the oil pressure switch - still no start. If I squirt starter fluid in the throttlebody it will turnover right now... The engine backfired several times weeks ago and now I'm thinking cam location sensor. Don't have a scan tool but need to get one.. Nother ?, where can I get a scan tool that will work on 95's? Seems like the OBDII's work on only the 96's and newer.. Any help will be gratefully appreciated.
Old 07-26-2005, 09:11 AM
tjm's Avatar
tjm tjm is offline
Re: 95 - Engine turns - doesn't Start
http://www.troublecodes.net/GM/
'97 Majestic Teal Metalic, 233,000 miles of smiles
Member of the AURORA CLUB OF NORTH AMERICA
Old 08-10-2005, 04:03 PM
Re: Re: 95 - Engine turns - doesn't Start
Originally Posted by tjm
Thankx for the info...
I finally found the NOT STARTING to be a fuse.. DUH.. However, when the vehicle was under load, it missed terribly.. Plugs and then wires.. Found that 2 terminals on the coils were really rusted and hardly making contact. Problem solved..
Three days later, missing again.. Son's car - so now I have to wait till he brings it back to take another look at it..
Thankx again.. Frank
Old 08-15-2005, 05:47 AM
Tony01 Tony01 is offline
Codes---Help
TJM
AM I missing something?
I looked under the code listing,,it has nothing for 95-4.0 L FI
help???
Old 08-16-2005, 11:50 AM
tjm's Avatar
tjm tjm is offline
sorry - Ive recently been told that the '95 is OBD-I with an OBD-II connector so ya cant use the old paper clip trick - gotta get it read with an OBD-I scanner
Old 08-16-2005, 12:07 PM
TJM-Thanks for the information---
Wouldn't ya know it..I have an OBD-II scanner.
If it has an OBD-II connector..what would happen if I plugged in my OBD-II scanner?
But better yet, wher is the connector. It's not visible under the dash panel?
tks
Old 08-16-2005, 03:23 PM
ghutchin ghutchin is offline
Nothing will happen since electrically and software wise obdI and obdii are entirely different beasts
Old 08-16-2005, 04:06 PM
Thanks, but I don't see the connector. is it hidden some where...?
Old 08-17-2005, 03:54 PM
Tony, you look straight up from the floor on the drivers side and there is a little sliding door. Slide it open and the unit is there facing the floor.. Frank
Old 08-17-2005, 03:58 PM
Obd
I've looked in Ebay and general search engines for the OBD 1. Plenty of OBD II's.. Can't find one.. Anyone know of a good scanner and where to purchase it?
Frank
