Old 07-25-2005, 04:25 PM
APMUWStout APMUWStout is offline
Send a message via AIM to APMUWStout
5 Speed
I was driving for a couple of hours, then stopped to get gas, then when I went pulled into the pump, i couldn't get it back into any gear. I eventually forced it into third gear, and took off in third, then it started working fine again. Then about another hour down the road it did the same thing at a stop sign. I force it back into third and it works again. It hasn't done that since after 4+ more hours of driving. But now it is harder to shift, like it doesn't want to go into gear, and reverse is practically impossible w/o grindage. Any ideas?
Its a 92 1.9 I read in my haynes it has a hydraulic clutch, and maybe it needs bleeding? I don't know how to handle that though.
Old 07-25-2005, 05:13 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Next time it does this try turning off the engine. If it slides in gear then it's probably a cluch problem. If it doesn't then it might be a tranny problem. MAKE SURE THE BRAKE MASTER CYLINDER IS FULL
Nevada Tumbleweed
Old 07-25-2005, 05:30 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: 5 Speed
good tip. on my 1999 the clutch and the brake cyl are one unit. If low means there is a problem somewhere.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 07-25-2005, 06:00 PM
Yes, but problem could be with brakes. I believe the line that feeds the clutch master cylinder is not at the bottom of the brake master cylinder. That way, a leaking clutch system could not completely drain the master brake cylinder which would result in loss of brakes. Not that that has anything to do with it
Nevada Tumbleweed
Old 07-27-2005, 06:58 PM
Its odd because it does it off or on. Sometimes (rarely) it works fine. I still drive it everyday, and it works, you can just feel it hit when I shift. And yes the brake fluid is full
Old 08-27-2005, 03:48 PM
music_freak9728 music_freak9728 is offline
do any of you know how to adjust a clutch.
do any of you know how to adjust a clutch?
