Old 07-25-2005, 03:55 PM
DREPDOM DREPDOM is offline
Unhappy 94 Acc alternator or battery issue
Hi experts,
I just don’t know what’s the problem but, when I try to turn on the veh the battery makes the tac tac tac noise and reset the clock just like if has not juice. Then I turn the key to off and then on again, it make a discharged noise but with more juice, turn the key to off and on a few times more and is like if the battery take more power and finally turn the veh on.
I tuned up the car and that didn’t help at all. I was told is the battery, but if is the battery how come after a few try the veh turn on. After the veh is running and I shutdown it won’t have any problem to turn back on if is without a few hours. Any idea?
Old 07-25-2005, 04:39 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Re: 94 Acc alternator or battery issue
it could be that your battery is weak, but how are your battery cables? I had the same thing happen to me, and it was just really coroded cables.
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
Old 07-25-2005, 07:22 PM
mpumas mpumas is offline
Check battery cables first. A volt meter across the terminals will tell you what is happening when you put a load on the battery.
Old 07-26-2005, 06:42 AM
I have not check the voltage yet, but for sure I checked the wires and clean the battery (poles, etc..). Sometimes I get the D4 flashing thing.
