Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-25-2005, 04:22 PM
D-Bo's Avatar
D-Bo D-Bo is offline
camber kits
so now that i can finally pay for some things on my car, i need to put my suspension in along with some new tires but i'm not ready to spend money on some decent summer tires if the camber from the suspension drop will wear them in 8000km. does anyone have camber kits on their cars? should i be able to find something on ebay? any reccommended companies?
thanks
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 07-25-2005, 04:37 PM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: camber kits
SPLParts.com
Not only the best designed parts but in most cases the Cheapest.
I know they have RUCAs and could probably get you Cusco camber plates for the front... I dunno if they're Front Strut perch will work with shocks.
P.S. the Powertrix crap on Ebay will do if your a risk taker. I have heard of them cracking and the Heim Joints squeaking.
Old 07-25-2005, 04:44 PM
D-Bo's Avatar
Re: camber kits
maybe i'm just technologically impaired but i can't find anything for the rear on splparts.com
edit: nevermind i found them
so should i be paying the $269 for the rear then $166 for the front?? is that all i'm gonna need?? i don't know enough about suspension
Old 07-25-2005, 07:16 PM
R.W.240's Avatar
Banned
Re: camber kits
Thats all you need to control camber if you want to adjust toe and caster you'll need more links.
Sportlines dont get the car too low... have you tried aligning it with the stock links?
Old 07-25-2005, 07:44 PM
Chuki_breath Chuki_breath is offline
Re: camber kits
you shouldnt really need that. Just get an alignment for like 70 bux...i got coils and thats all it needs.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 07-26-2005, 12:08 AM
D-Bo's Avatar
Re: camber kits
well then if i'm buying new tires, are they gonna wear on the inside a lot still?? i mean i'm dropping it 1.9" in the rear. i'm pretty sure there's gonna be some kind of camber problem but the question is how much. i'm not concerned so much about the front cause it seems to be the wheels that get power to that have the most camber problems. or maybe i'm completely wrong about that. i don't know. maybe i'll try it without the camber kit and see how things work and if i see more wear on the inside then i'll think about adding more.
Old 07-26-2005, 02:14 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: camber kits
ahahahha i spent 20 bucks and got some adjustable bolts that replace where the strut bolts to the hub.
good for a few degrees camber +/-
dont remember what brand they were but they were just bolts with a cam lobe on each so when you turned the bolt it would swing the strut/hub in or out.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 07-26-2005, 11:41 AM
D-Bo's Avatar
Re: camber kits
ok i know what you're talking about. all you have to do is replace the old ones with the new bolts and it'll help a little??
Old 07-26-2005, 08:47 PM
Re: camber kits
rears dont usually move that much. When i put my coils on....the rear practically didnt need adjustment. The front is what fucks up the most. Mine were like -3 degrees lol. The rear was like -1. Just get an alignment, im telling you man thats all you need.
Old 07-26-2005, 09:30 PM
orestes's Avatar
orestes orestes is offline
what about these.
"UAS REAR UPPER CONTROL ARM BUSHES
ADJUSTABLE URETHANE BUSH WITH OFFSET CAMBER PIN. THE BOLTS HAVE A PLINE TO ADJUST IN CAR. CAN BE USED FOR INNER AND OUTER TO GIVE AROUND 2.5 DEGREES OF ADJUSTMENT, OR 1 DEGREE IF ONLY PAIR IS USED.
PRICE: $95.00 PAIR "
and how does that work with more than 1 set being installed? is it one goes from the arm to the hub and one on the other side from the arm to the subframe? so 2 on each side to get more than 1 degree?
and if you have to buy 2 sets of those then it comes out to about the same price as these, what would be the better buy? easiest install?
"I got that hustle in my genes like high blood pressure" -E-40
Old 07-26-2005, 09:49 PM
D-Bo's Avatar
Re: camber kits
holy shitballs orestes, those look like they weigh 200lbs each..
thanks for doing the research and thanks for the info boys. what i did was order tires today and the bolts and we'll see how that goes with the 2.1F and 1.9R drop. i'll let you guys know
by the way, i ordered 195/50R15(F) 205/50R15(R) in toyo proxes 4 (all season performance tire - which sounds super but they're actually decent tires)
this link is for you lazy sob's
http://www.toyocanada.com/products/Proxes4.asp
Old 07-26-2005, 10:19 PM
orestes's Avatar
lol ya sorry for that gigantor pic. but any opinions on 2 sets of those rather than $200 adjustable RUCA's??
Old 07-27-2005, 03:28 AM
D-Bo's Avatar
Re: camber kits
i know nothin about them but if someone does, it'd be interesting to hear about them
Old 07-27-2005, 01:25 PM
R.W.240's Avatar
Banned
Re: camber kits
get your car alinged before you go out and start buying shit... I doubt you'll need Crash Bolts or RUCAs because of a 2in drop.
Old 07-27-2005, 08:09 PM
Re: Re: camber kits
agree'd. been trying to say that. If they happen not to line up THEN you buy that shit....but they will so no worries.
