Old 07-25-2005, 02:43 PM
86celica_gt 86celica_gt is offline
!!! Idle Adjustment Help !!!
My 86 celica gts is idleing a little low at around 500. I'd like it to be somewhere around 1000-1300. Where can I locate the the adjustment screw. I haven't got a clue where it is. I do know where the throttle is though.
thanks
Old 07-25-2005, 03:38 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
should be located near the throttle body bracket. Should just be as simple as turning a screw.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 07-25-2005, 04:02 PM
Re: !!! Idle Adjustment Help !!!
that's what I thought, but there's nothing that really stands out. Is the body bracket located to the left of the throttle cable? Will it be underneath or on top?
Old 07-25-2005, 11:22 PM
Re: Re: !!! Idle Adjustment Help !!!
im not familar with the celica platform. Im just speaking from experience with my own car.
"The CEG Nazi"
www.contour.org
Old 07-26-2005, 01:14 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
if you have a EFI car with a idle air control solenoid/motor, the manufactior may not want you to adjust it, as it should be perfictly preset at the factory. if this is the case, your problem lays elsewhere. check your emission sticker or owners manual to confirm.
etherway, the screw should still be there, it may be covered with a plastic/rubber boot. check the bracket the throttle calbe connect to, it is probilly the only thing that is in its way prevent it from closing anymore.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
