Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 07-25-2005, 03:41 PM
86celica_gt 86celica_gt is offline
Unhappy !!!idle Adjustment Help!!!
My 86 gts is idleing a little low at around 500. I'd like it to be somewhere around 1000-1300. Where can I locate the the adjustment screw. I haven't got a clue where it is. I do know where the throttle is though.
thanks
Old 07-25-2005, 06:34 PM
barkroc2's Avatar
barkroc2 barkroc2 is offline
Re: !!!idle Adjustment Help!!!
not sure on an 86, but your in the right vicinity w/ the throttle.
"I'd like it to be somewhere around 1000-1300"--
that high, especially w/ the price of gas nowadays
1990 Celica GTS
Old 07-25-2005, 06:40 PM
Re: Re: !!!idle Adjustment Help!!!
I'd at least like to know where the screw is. Can you find it on yours? It's probably not that much different. Is it to the right or left of the throttle cable?
I should have said this in the orig. post, but it gets down to about 200 or so when driving. It's at 500 when I start it.
Old 07-25-2005, 07:31 PM
barkroc2's Avatar
then dont just turn up the idle...find why its dropping and fix that. & im not sure its possible to do on mine
1990 Celica GTS
barkroc2's Avatar
check your vac lines for splits/cracks
1990 Celica GTS
Old 07-26-2005, 04:48 AM
91 Celica St 91 Celica St is offline
AF - Advisor
you should idel at 800 after the warmup process is complete by the ecu....if you had a fat hole in your radiator would u try and repair it with ductape or would you go out and buy a new one?
dont cut corners it can end up fucking something up in the long run, find the problem and find a solution, curing the symtoms dosent mena u cured the problem
Old 07-26-2005, 05:26 PM
barkroc2's Avatar
--well said brother.
1990 Celica GTS
