1991 Pontiac Sunbird-----HELP
I have a 1991 Pontiac Sunbird 4cyl.
I have dump about $150 in it the past month and am not getting anywhere with it.
It will start and run for about 15-20 min then seems like it is not getting any gas to keep it running.
I have replaced the timing belt, starter, plugs, wires, ignition coil, ignition module, distributor cap, rotor, fuel filter, and fuel pump.
what else can I dump into it to keep it running longer than 20 min.
was thinking that my alternator was getting weak so not having enough voltage for the fuel pump to operate properly. am going to have that tested tonight. also heard of a part called the distributor coil pickup. do you think that might have anything to do with it? and if so, what does it look like and where would I find it?
Please Help......I need this car.
