Old 07-25-2005, 12:28 PM
thezoz2001 thezoz2001 is offline
Fuel system problem
Specs
2001 Escort w/2.0 SFI
67Kmi
Tuned up about 3 weeks ago, New plugs, wires, all filters.
In the last few days the car has a problem starting (must turn over several times to start). Once started it hesitates every now and again on flat roads, but under a load (like going up a hill) it hesitates alot and the service engine light start to blink and then stops. The blinking will come on again with 10 or 15 mins it I still going up a hill. I thing it is the fuel system but I am not sure where to begin. Please advise. Thenks David
Old 07-25-2005, 01:14 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Maybe you can get the codes read to see why the light is blinking.
Nevada Tumbleweed
Old 07-25-2005, 02:02 PM
mlw35405 mlw35405 is offline
Re: Fuel system problem
Blinking SES light means misfire. Check that none of your plugs are cracked, and that the wires are not burned and are installed and routed properly.
The young and the young at heart wait,
But the wait never ends in the soul,
When you feel like its all blown away,
Independence has come,
And into the night I go...
Old 07-26-2005, 12:40 AM
95cobra5.0 95cobra5.0 is offline
Send a message via Yahoo to 95cobra5.0
Obviously the posibilities here are endless, but if I had to guess I'd say fuel pump. One way to possibly diagnose it without a pressure gauge is next time you start the car, before starting it turn the ignition switch to the on position for about 3 or 4 seconds without trying to start it. Turn it off and immediatly on again, but this time after the 3 seconds go to start. If it fires right up with this procedure I'd bet it's the pump. Well actually it could be the check valve at the pump, but I don't think it's available separately. Please post your results to help us all out!
Old 07-26-2005, 06:58 AM
Good point cobra. With a bad check valve the fuel would go back into the tank after shutdown. Making it hard to start.
Nevada Tumbleweed
Old 07-26-2005, 07:53 AM
When the light is blinking, it indicates the computer senses an active misfire, when the misfire goes away, the light will stay on steady and log a trouble code. Also, since he just changed the plugs and wires before it did this, I'll be willing to bet that he has a burned spark plug wire or cracked plug insulator...
Old 07-26-2005, 10:53 AM
Thank you all for input. This what I have done so far.
Changed the Coil and wire set, and check the plugs, - did not help
Changed out the fuel pressure senser - did not help
Read the codes off the computer - no codes given.
My first thought was the fuel pump, but I did not know how the test it. When I go the start the car, I put the key in the ON position till the fuel pump stops running. then I go start the car but it never starts. Then I turn the key to off and then back to the on position till the fuel pump stops and then start the car, sometimes it will start sometime I have to do it again to start the car. This morning I took it in the have a diag done. I will post the results. I wish I could work on it longer but we need to car up and running ASAP.
Old 07-26-2005, 11:29 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Sounds like a fuel pressure regulator problem to me. When they go bad they do not hold pressure and will make the car hard to start. Will also cause misfires if the pressure is too low.
Old 07-26-2005, 03:09 PM
Re: Re: Fuel system problem
Thanks for the input, but there is no fuel pressure regulator on the 2001 escort. It has a fuel pressure senser. Anyway it is the fuel pump, I just got the call from garage and that is what they found. The pump is running at about 14 psi and should be running at 55 - 85 psi. thats a quick $600.00 down the tubs.... Thanks everyone for the help.
Old 07-26-2005, 03:46 PM
Pontiac Guy
Thanks for the post. It seems like Ford has a better idea by not putting regulators on these cars. Makes them more money when the pumps wear out prematurely.
