Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-25-2005, 11:51 AM
chibears85 chibears85 is offline
Driveline Vibrations
I own a 95 YJ, and I'm installing a 3.5 inch lift, and droping the T-Case an inch. Does anyone think that I will run into vibrations??? Or will I be ok, any opinions are appreciated. Thanks
Old 07-26-2005, 11:40 AM
JDPascal JDPascal is offline
Re: Driveline Vibrations
The consideration most important is that the centerlines of the pinions need to be parallel to the centerlines of their transfer case output shafts. If that is right, you should have no problem with vibrations.
JD
Old 07-26-2005, 01:22 PM
awesome, thanks
Old 07-26-2005, 01:24 PM
also - just remembered there is a maximum angle that is allowed or you get a vib too. cant remember it right off tho.........
JD
Old 07-26-2005, 06:09 PM
ya, ive heard those vibs start happening around 3 inchs, does anyone know this for sure from experience??
Old 07-26-2005, 08:47 PM
Ya got me curious cause I couldn't remember it so I just looked it up. Max recommended angle is 3 degrees between the parallel centerlines of the pinion/TC output shafts and the drive shaft (for a standard u-joint shaft).
The maximum lift before you exceed the 3 degrees will depend on the length of the drive shaft.
JD
Old 07-27-2005, 10:44 AM
so if i do get vibs, whats the best/cheapest way to fix it?
Old 07-28-2005, 05:15 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
Get rid of the slip yoke. Gives you a longer drive shaft and less angle.
1995 Jeep Wrangler
3 1/2" lift 33x12.50 tires
4.5L stroked I-6
Bored throttle body & Cold Air Intake
Jet Chip Stage 2
Jet Thermostat
Colorado Off Road Rig!!!
