Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 07-25-2005, 09:34 AM
RevJBJ RevJBJ is offline
Rear Heater controls
(1998 Silhoutte) My rear fan will work when I controll it from the front of the van. but when I allow the people in the rear to control thier own heat, the blower will not come on. when I switch it off R, I can control it from the front. Please help.
Thank you.
Old 07-25-2005, 11:03 AM
GregA's Avatar
GregA GregA is offline
Re: Rear Heater controls
Thank you.
It is probably something in your rear control panel. My schematic says there is a relay and some temperature control circuits in there (active components - most likely to fail).
I would try to pull it out carefully and then listen for the "click" of the relay when you switch the main control to "Rear." If you don't hear it, the relay could be bad, or there could be a loose connection to the rear control module. If the temperature control circuit is bad, you will probably have to replace the whole control module, but check that the rear temperature control knob is on full cold first.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 07-25-2005, 01:23 PM
Re: Re: Rear Heater controls
How do you remove the switch. I dont want the whole header to fall down. Is there screws or does it snap in place uptop?
Old 07-25-2005, 02:02 PM
GregA's Avatar
Re: Re: Re: Rear Heater controls
I don't have the rear AC system, so I don't know. But based on experience, if you can't find any screws, you can probably find a plastic notch around the outside of the control unit where a small screwdriver can be used to pry the unit out. BUT ... you might want to wait for some input from other folks here.
UPDATE: My manual says to use a small flat-bladed tool to pry and release the mounting tabs of the control. If you have the overhead system, this appears to be just the knob and control assembly, NOT the entire assembly.
Take Care,
Greg A.
Old 07-25-2005, 02:26 PM
GregA's Avatar
Here is a drawing. If it matches your van, prying should work (but do it gently).
Rear AC Controls - Removal
Take Care,
Greg A.
