Ranger a/c unit
4.0L V-6 Automatic
R134-A refrigerant I guess this is the time of year for a/c questions, and I have one ![]() I am not sure which approach to take on repairing my a/c unit. Before the problem occurred, the a/c compressor ran in 4-5 second cycles but cooled ok and it operated that way for some time. I quit using the a/c because of the short cycles. Recently I turned on the a/c out of forgetfulness and it did not cool at all. The compressor still tries to operate in short cycles. Does this sound like a compressor on the way out or a need of freon? Any help appreciated. RR |
Re: Ranger a/c unit
Im not sure what year your truck is but read my post under lospalos thread it might help
Re: Ranger a/c unit
Typical low-refrigerant symptom.
Re: Re: Ranger a/c unit
Thanks guys............
This is what I learned in case it helps someone in the future. Just add refrigerant only, no oil or other additive needed unless you changed the accumulator or you see lots of oil that has leaked out. First can of R-134a can be added upside down until compressor starts to engage and stays on. I actually layed 1st can on its side. After compressor engages hold can upright as not to damage the compressor. Put the R-134a can in warm water to speed up the process. Pressure gauge highly recommended. Low side is on left side of engine on accumulator (small vertical tank) 1992 4.0 V-6 |
Re: Re: Re: Ranger a/c unit
