my 87 taurus turn signals will not work at all--i done checked all the fuses-they are good-i replaced the turnsignal/hazard switch--the 4 way flashers work-but not the turn signals
Re: turn signals
Are you getting power to the turn signal switch? Have you tested the relay?
Re: turn signals
yes im getting power but nothing at all
Re: turn signals
Is power going to the relay?
Re: turn signals
It might be the multi function switch which is the actual handle that swtches the blinkers ,wipers,bright lights on and off.etc
Re: turn signals
what exactly is the relay
Re: turn signals
Time to look at your wiring diagram and follow the circuit and test each component. Don't forget to check the grounds.
Re: turn signals
I had to replace the relay in my old 89 Taurus wagon I had, its located up under the dash just to the left of the steering column, you have to reach up in there. The relay costs about $12 if I recall. I lost all turn signals and emergency flashers until I replaced the relay
