Originally Posted by 72_supernova
Hey I'm looking into getting a 93 or up Z28 with a LT1 and was wondering how much it would cost to rebuild the engine without going overboard with expensive parts. Just stock to moderate performance parts is all that I would want to do. I would have a shop do it just because I don't like messing with all the computers and electronics. I've got a 72 Nova and the charging system is about as technical as I care to get. Oh and this would be a rebuild on a engine that is runing fine (not a cracked block or anything). Thanks for any help.
Well if u don't make the motor hot the block work $150-200 rod and main bearings $75-100,new cam bearings $50-80,oil pump $50-80,gasket set $50,new cam & lifters $150, pistons if needed $300, rings $35-50 for stock type,valve stem locks $30, valveseals $25,new springs if needed$40-130 depends on that type.SO you do the math it can range from $500 to $1200 in parts and thats not adding the labor from the shop.IT jest depends on what type of a build you want to do.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img
[/img]
