Old 07-25-2005, 02:07 AM
HiT-TheNos420's Avatar
HiT-TheNos420 HiT-TheNos420 is offline
Blown Shocks
I just bought a 95 gst with a blown rear left shock. I am just going to replace both rear shocks and I was wonder whats the best setup for under $300 for 2 rears?
Old 07-25-2005, 11:01 AM
Gsx_hooptie Gsx_hooptie is offline
Probably Tokico Illuminas, if you'll upgrade the rest of your suspension later. If you don't plan on upgrading your front shocks at a later date I wouldn't bother putting anything better than stock in.
I would upgrade all four at once, with springs. Then again, money is always a problem.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 07-25-2005, 03:59 PM
I looked up some tokico illuminas for my 95 eclipse, but they are non-adjustable. My car is already 2 inches from the ground, am I able to adjust the rears to my previous settings? I am confused.
Old 07-25-2005, 06:40 PM
MoozillaGSX's Avatar
MoozillaGSX MoozillaGSX is offline
Send a message via AIM to MoozillaGSX Send a message via Yahoo to MoozillaGSX
Re: Blown Shocks
no Illuminas are preset at i think 1.75 inch drop from stock. your front end at its lowest point would probbaly be around 3" but the back will sit higher, its because of the way the car is made. smaller shocks up front than in rear.
you would have to buy something more expensive to be able to adust the ride hight. if you have 1 grand go look for a good deal on some Tein coil over system , with the right pair you could adjust it your self.....i wouldnt spend that much money though just to change the ride hight lol.
i have Tokico hp blue's, got mine off E-bay with springs too for liek 385 or somhin like that.
but ya if your not going to upgrade the front it wouldnt be worth it to upgrade just the rear.
Austin - 95 GSX .
-K&N FIPK.
-Ijnen UICP + Greddy RS BOV.
-Rota Slipstream + yokohoma Es100's.
-Tokico HP Blue's + Springs.
-Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads.
-Manacore Wires.
( got a 20g and the works in the clothset )
Old 07-26-2005, 11:09 AM
1) What were you running in the rear, what are you running in the front?
2) Shocks don't lower your car, springs do.
3) Illuminas are made for stock ride height, and running them at anything other than stock voids their warranty.
4) Tokicos adjust dampening and rebound together, on five different settings.
5) It doesn't have to be expensive to adjust ride height, plenty of shoddy coilover systems do it Ground Controls would also do it, if you wanted something that didn't suck.
Old 07-26-2005, 09:29 PM
Re: Blown Shocks
oh my setup came with springs. i didnt realize that without them they were for Stock ride hight. thats probably why my cars rides 1 3/4's inches lower than stock, which in my opinion is stupid i didnt know that 1 inch and 3/4's would make such a huge diference. i hate how low m car rides in the front. it sux, im a god damn snow plow lol.
Austin - 95 GSX .
-K&N FIPK.
-Manacore Wires.
Old 07-27-2005, 10:57 PM
All my shocks are stock mitsubishi. Nice information from everyone, I appreciate it.
Old 07-27-2005, 11:11 PM
Re: Blown Shocks
ive nevr had blow shocks before nor seen them. can anyone tell me how to tell when your shocks are bad ?? im sure its one of those things that youd have to be extreamly stupid to not be able to tell. but just outa inexperience i would like to know. thanks.
Austin - 95 GSX .
-K&N FIPK.
-Manacore Wires.
Old 07-27-2005, 11:35 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
The job of shocks is to absorb the up and down motion of the spring. When your shocks are bad, the car will keep bouncing for a longer time after you hit a bump or something.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-28-2005, 12:16 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Blown Shocks
or if you start to hear a clunking noise in the suspension system if you hit a bump or something. push down on each corner of the car and listen to that shock/strut and if it clunks....replace it.
95 Talon TSI AWD
97 Eclipse GST
Old 07-28-2005, 11:28 AM
ted_ex's Avatar
ted_ex ted_ex is offline
Re: Blown Shocks
Your shock can also leak fluid if a seal is bad. This is what I assume people mean when they say the shock is blown. I have a leaking shock on my car right now and you can see the fluid on the sides of the shock.
I'm>everything
Old 07-28-2005, 07:51 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Blown Shocks
Did I miss something? "my car is 2 inches from the ground" Does this mean you are running lowering springs and stock shocks? No wonder they are blowing.
Old 07-28-2005, 08:03 PM
Listen to Joe.
As was said, fluid leaking is bad. If you suspect the shock is bad, place weight on the car and watch the rebound. Then, pull the shock and test it between your hands.
