Old 07-25-2005, 01:15 AM
g-ride-si's Avatar
g-ride-si g-ride-si is offline
Bad Rings? CAI?
I have 2 questions. first i have a b18a that i took out of a 91 integra i had it running good eventually but it was smokin pretty bad. when i got it there was water in the number 1 spark plug so i soaked it up and put new plugs in. then the screw came out of the rotor and it was firing like crap. So could the smoke have been from a/f ratio bein off really bad or a head gasket. the smoke was white and blue, mostly blue?
Also, if i do swap this motor into my 89 si hatch should i use a cai for the hatch or will it not fit under the hood... if it matters im using hcp mounts
Thanks
Ryan
Old 07-25-2005, 02:05 AM
g-ride-si's Avatar
Re: Bad Rings? CAI?
nevermind about the cai i finally went through all the threads that showed up in the search...i need the teg intake
Old 07-25-2005, 07:30 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Bad Rings? CAI?
Blue smoke is oil- it could be rings or valve seals. If it just does it when you start it then its valve seals, if it does it after you start it and keeps doing it then its rings. It could also very likely be a head gasket - expecially since you said it had water in it.
Old 07-25-2005, 08:13 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Re: Bad Rings? CAI?
90% of the time valve seals are the culprit.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 07-25-2005, 03:24 PM
g-ride-si's Avatar
Re: Bad Rings? CAI?
thanks do u think its worth putting it in my hatch?
Old 07-25-2005, 03:30 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: Bad Rings? CAI?
re build it and then put it in.
Old 07-25-2005, 05:16 PM
BiGwiLLswiLLy BiGwiLLswiLLy is offline
Send a message via AIM to BiGwiLLswiLLy
Old 07-25-2005, 06:07 PM
g-ride-si's Avatar
Re: Bad Rings? CAI?
ive never rebuilt any motors just swapped them and worked on them and supposedly its a low mile engine saw receipt saying it has around 90,000 mi would it be ok to just replace rings and head gasket?
Old 07-25-2005, 06:11 PM
Kind of a Big Deal
Re: Bad Rings? CAI?
but while your in there, you may as well rebuild, its not hard, just buy a helm's manual for that engine.
Old 07-25-2005, 11:29 PM
Forunn Daberator
Re: Bad Rings? CAI?
I'd just hone it, put in new bearings, gaskets, rings and be done with it.
Old 07-26-2005, 04:34 PM
g-ride-si's Avatar
Re: Bad Rings? CAI?
ok thanks im takin the head off today ill let u guys know what i find
