Old 07-25-2005, 12:39 AM
ItsBrokeAgainChevy ItsBrokeAgainChevy is offline
'99 With a Coolant Leak
No coolant in the oil, no oil in the coolant. It took a long time for the leak to be located. Only small amounts of missing coolant and the faint odor of a leak. Now it is a steady flow once hot. It appears to be a gasket behind the thermostat housing. Can't get a mirror in there to check/locate the exact location of the leak. Am assuming until I hear otherwise that this is the infamous Upper/lower intake manifold gasket leak. What is involved in tearing this thing down and doing the repair?
Old 07-25-2005, 12:35 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: '99 With a Coolant Leak
It might be, I just went out and had a uick look at my '97, there are small hoses going to the throttle plate, and a quick disconnect where the heater line comes into the manifold, any of which would cause a leak in that area, if you have the same motor (3.1)
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 08-19-2005, 04:54 PM
Update
Yep, it was the famous/infamous plastic lower intake manifold gasket. If one can be lucky, I was. The water/coolant leaked outside and not into the crankcase. It was a pain, but not really difficult enough to have to pay somebody to do it for me. Buy a Haynes manual and follow it step by step. One thing I would do different from their instructions. Leave the injector rail and injectors in place, it is a little more difficult, but not having to beat the injectors back into their holes - without messing them up - is a plus. Remove the fuel line and the pressure regulator from the injector rail and buy new o rings. Damn the piece of filth engineer(s) that designed the sideways 3.1 V6.
Old 08-22-2005, 11:49 PM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
My 99 had a tiny, tiny leak (headgasket seal fails). Driving does the road on the, the rest of it went. Then stuff was crazy. Anti frees got in the oil. After that happened, the engine siezed (I broke 2 pitsons, plugs, and vallves.)
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
