Old 07-24-2005, 10:51 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Computer beeping....odd
Okay my computer is going crazy now. About 2 weeks ago i finally hooked my computer up after moving back home. The first time i turned it on there was a horrible clicking sound, obvious sign of the harddrive starting to fail. It had done it in the past one or two prior times that i can remember but made the clicking for a few seconds and stopped those times. Which brings me to today. I just turned it on and it started making this annoying beeping sound. Probably around every second of so. Does anyone have any wild guess as to what's going on? This is driving me mad.
Everything works fine though, no slow downs or other gliches, other than my video card still doing stupid stuff that i have never gotten to the bottom of. Any thoughts at all would be great.
*Under Construction - New sig to debut*
Old 07-25-2005, 01:55 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Send a message via AIM to Oz
Re: Computer beeping....odd
How many beeps, how long after boot, any other symptoms?
Originally Posted by RaeRae1
Blessed are the cracked ones for they are the ones that let in the light.
Old 07-25-2005, 06:04 PM
It's just a constant beep, pretty much as its loading up and just continues endlessly. But i turned the computer on today and it didn't happen. Who knows, very bizarre.
Old 07-25-2005, 06:33 PM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Consult your m/b user manual. Could be dodgy RAM, failing hard drive, incorrectly configured IDE cables, power or pretty much anything depending on your make and model.
Old 07-26-2005, 06:59 PM
Thanks for your help Oz.
Old 07-27-2005, 01:46 AM
Oz's Avatar
Oz Oz is offline
Aussie Mod
Did you find out what the problem was? The manual often tells you how many beeps correspond with which fault.
Old 08-06-2005, 10:17 AM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Sometimes it's as simple as a loose circuit board of some sort. Make sure all the RAM and PCI/AGP cards are pushed in all the way and that there's no loose IDE/SATA or power plugs anywhere.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
