Old 07-24-2005, 07:28 PM
ATMDC's Avatar
ATMDC ATMDC is offline
2 questions intake & oil
1. Do those intakes on ebay for 15 dollars work any good? like just for my d15 for sound until i get a swap? and if not to good, what if i just put a better filter on it. or whats the best ebay intake for 40 dollars of less, not including shipping?
2. if im bout to change my oil, i only have 2 jack stands so the car front will only be up, will this affect the amount of oil that comes out? or does the car have to be level off of the ground?
thanks guys
Old 07-24-2005, 08:02 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: 2 questions ontake & oil
Its a bent tube they all work the same, just put a good filter on it.
No it wont matter.
Old 07-24-2005, 10:10 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Just when you are putting oil back in, make sure that your car is level when you check and see how much more oil you have to put in.
1986 Honda Accord LX-i 5 spd
Completely stock... but i like it anyway, it's got a strong e-brake
www.cheesemit.us
http://www.cardomain.com/ride/862348/1
Old 07-24-2005, 10:39 PM
ATMDC's Avatar
Re: Re: 2 questions ontake & oil
of course, but thanks, cuz some how i feel i would have forgotten any ways
and also thanks about the intake, ima buy one now
Old 07-25-2005, 01:45 AM
BullShifter's Avatar
Re: Re: Re: 2 questions ontake & oil
Ebay intakes have cheap filters which reduce air flow, change to K&N. The biggest difference between ebay junk & name brand is the name brands are CARB approved.
Old 07-25-2005, 07:40 AM
ATMDC's Avatar
so does that mean if i dont have a carburaetor then i dont have to worry bout it, just get another filter?
Old 07-25-2005, 07:44 AM
Forunn Daberator
Thats good. lol. CARB is emissions certifications.
Old 07-25-2005, 07:58 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
I used two jacks 2 days ago to change my oil in the yard. Just put the oil collector under the oil pan, loosen the pan bolt (17mm or 11/16"), loosen oil cap, let it all drain out, remove and replace oil filter (put some oil on the gasket of the oil filter), replace oil pan bolt, lower car to level, fill with at least 3.5-4 qts. of oil...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 07-25-2005, 10:34 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
and repete in 2-3 months
Old 07-25-2005, 10:57 PM
ATMDC's Avatar
damn, my book says 3 quarts and thats all i bought so do i need to get another one?
Old 07-26-2005, 12:33 AM
That's because you got a Haynes manual, buy a factory manual if want correct specs - www.helminc.com
CARB doesnt mean carburetor
CARB is California Air Research Boad certified. Some states will not allow you to pass emissions without a CARB approved aftermarket part. The filter don't make a difference, you don't even have to use one but that's a bad idea for every day driving.
Old 07-26-2005, 09:02 AM
ATMDC's Avatar
one more thing, i just bought 5w-30 oil and the owners manual says this is good for fuel economy, but im not worried about that, the 10w-30 says its good for 20 deg.F - 100+ deg.F but the 5w-30 is for -20 and 100+, and the temperature here will never hit below 20. so should i get 10w-30 or is the 5w-30 fine?
Old 07-26-2005, 09:11 AM
It really doesn't make much difference. I was using 10w40 but I don't want sludge so I use 10w30. But as soon as real oil matches syntec, I'm switching to that... $2.36 for Castrol GTX 10w30
2010 Honda CR-V EX
Old 07-26-2005, 09:23 AM
ATMDC's Avatar
so if you think the motor is gunna be revved kinda high sometimes the 10w would be better or it still dont make a difference and i could use the 5w?
Old 07-27-2005, 12:39 AM
The first set of numbers(5w, 10w, etc.) indicates the viscosity when cold, if your revving high with a cold engine your At operating temps 5w-30 & 10w-30 do the same thing. In a warm climate 10w-30 will be just fine.
Read this - More Than You Ever Wanted to Know About Motor Oil
