Old 07-24-2005, 07:02 PM
JRockinVR4 JRockinVR4 is offline
Question 4WS Problem
I've been working on my VR4 quite a bit lately and the point came around to examine the 4-wheel steering. Me and my buddy were checking it out today. The car was parked and the wheel was cranked in both directions several times, but to no avail; the rear tires were not moving. My buddy spotted the rear steering bracket, but he said he couldn't see that moving, either. I drove around in the cul-de-sac in a circle a few times and the same thing, he said he couldn't see them turn with the front tires. I've been searching the internet all day and I haven't been able to find a single topic on 4WS problems. Also, my 4WS oil seems to be fine, according to the instrument cluster, but where is oil added in case it's low and does it use PSF or ATF?
Thank you for the help!
Old 07-24-2005, 07:31 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
Re: 4WS Problem
First of all ur not gonna see them move by the car just sittin running an u turning the wheel all the way, Second you wont see them move driving in a slow circle either - u have to be going 60mph or more for the aws to start working yes its speed rated anything over 60mph the aws starts functioning.
Hope that answers your question- sounds like u have nothing to worry about. Good Luck!
93' Stealth R/T Twin Turbo Intercooled - 24v DOHC 3.0 v6 engine - AWD AWS - 320 hp 317 lb ft. torque when I bought her unmolested hoping to be in the 600-700 hp when finished with ...
~FASTER THAN A SPEEDING TICKET~
Old 07-24-2005, 08:12 PM
Re: 4WS Problem
Thank you for the response
Actually, the reason I wanted to know was because I was told recently that the 4WS works if you are going 30 MPH or slower in order to take shaper turns with less headache. This is my only current car (as in a back and forth to work and such) and I haven't taken many high speed turns at all; if I do, I can't pay attention to the rear tires due to keeping my eyes on the road.
Thanks again! Cheers!
Old 07-24-2005, 10:27 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 4WS Problem
ya, you won't see or even feel the 4WS kick in. it operates only at high speeds, above 32 mph if i remember correctly. And the 4WS system is not a pinion system like the front steering system. 4WS is a fluid pressure system. So it takes a certain pressure build-up in the fluid to activate the rear steering mechanism, hence the operation only above a certain speed. Also, the rear tires only turn 2.5 degrees maximum. Though this does help at high speeds when cornering or better yet when weaving on the highway or on a road course, you would not feel its effects at low speeds.
the only way i can think of to test for its proper function is to put the car on a lift or 4 jack stands, take it up to about 40+ mph, turn the steering wheel and check to see any gradual turning in the rear tires. ***NOTE: this probably isn't a very safe thing to do.***
don't worrt about the 4WS. its most likely works just fine. i've never heard of it not working. i have only heard of people removing it b/c it only turns the rear wheels a max. 2.5 degrees, and so they will remove the pump and lines to save like 10 lbs in weight.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-24-2005, 10:28 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: 4WS Problem
Its 30mph and above, and its same phase with 1.5 degrees of turning. Its basicly for high speed lane changes.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 07-25-2005, 02:28 PM
Re: 4WS Problem
where did u guys here 30 mph i have only read info about if for 60mph+ is when its functional?
Old 07-25-2005, 02:40 PM
Re: 4WS Problem
Its 30, there is a PS pump in the rear diff that only builds up enough presure when above 30. I dunno where I read it, but thats what it is.
Old 07-25-2005, 03:35 PM
G35turbo G35turbo is offline
Re: 4WS Problem
it is acctually 31mph to be exact and i have read from 3 or 4 different websites.
1997 Mitsubishi 3000GT VR-4
Greddy Profec B II boost controller set at 14psi, Greddy Turbo Timer, Stillen downpipe, Turbo XS RFL BOV, Walbro 341 Fuel Pump, intake, ACT Heavy Duty Street Clutch, AutoMeter boost and A/F gauge, AutoMeter gauge pod, Viper Alarm System, 15% Tint, 18x9 Saleen Wheelz, Bluethunder sparkplug wire.
best track time 13.191 with lots of problems.
Old 07-25-2005, 03:37 PM
lamehonda's Avatar
lamehonda lamehonda is offline
Re: 4WS Problem
Talk about alot of conflicting numbers lol
1987 Honda Accord LX-Dead
1999 Honda Accord EX-L 5 sp-Sold
2006 Subaru WRX Wagon 5sp-Sold
2005 Nissan Frontier ext cab 4x4 4.0L-Sold
2006 Kawasaki Ninja 500r-Sold
2004 Yamaha FZ1 Silver/Black- Sold
2008 Mazdaspeed 3-In the driveway
Old 07-26-2005, 04:59 PM
Re: 4WS Problem
lol in the 1993 owners manual - for my car it says it becomes funcional at 60mph... maybe they messed up an put that in by accident...
Old 07-26-2005, 07:50 PM
Re: 4WS Problem
interesting..........yet I dont care to do enough research to actually find out. I just want the rear rack from a z15a car.
