After a thorough cooling system flush, a new thermostat, new coolant tank cap, and a new waterpump all I have not figtured out is my rad fan. I can let the 96 SC2 idle for ten minutes and no fan. I turned the AC on and no fan. I disconnected the ECTS and jumped the wire connecter and the fan ran. I also disconnected the air charge sensor. The fan will run with out the ECTS jumped also. I am seriously concerned about all of this as I do not want to cook a motor or a new water pump. Is there some definitive way to know the cooling fan is operating properly.
Thanxs in advance. |
Re: Phsyco cooling fan from hell.
correct me if i'm wrong - the fan will turn on if the ECT is jumpered or the PCM enter diagnostic mode, the fan will not turn on with the A/C or when the engine is hot.
is the A/C working properly? the ECT is the new version correct? was the car bought new or used?
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles EPA 608 Universal Certification EPA 609 Certification |
Re: Re: Phsyco cooling fan from hell.
The AC does not work. Next project. The fan finally did come on but only after the temp gauge past the halfway mark. |
Re: Re: Re: Phsyco cooling fan from hell.
if you have a blacklight availible, use it to check the underhood a/c components, with any luck there is/was tracer dye in the system and if you have a leak it should show up.
Re: Re: Re: Re: Phsyco cooling fan from hell.
i don't have expearince ether way, but i would say new. R-134a can be very corrosive when mixed with the slightest bit of water (as little as one drop of water per 100 LB of R-134a). with used, you don't know what you are getting.
