Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 07-24-2005, 03:32 PM
kron11 kron11 is offline
Looked at a 95 today...
not bad, body was very decent...but
-Tick tick tick coming from the valve cover...
- Idle dips when u left of the throttle to idle...
- And a thumping noise from the rear right shock when we hit bumps...
any ideas about that ths shock?
Old 07-24-2005, 03:42 PM
jon@af's Avatar
jon@af jon@af is offline
The Media Guy
Send a message via AIM to jon@af
Re: Looked at a 95 today...
Might just need to replace the shock.
AF User Guidelines <----Click and read if you don't know these.
"Dream as if you'll live forever. Live as if you'll die today."
A Blog By Swigz
Cotidie damnatur qui semper timet; Aquila non captat muscas.
Old 07-24-2005, 05:31 PM
D-Bo's Avatar
D-Bo D-Bo is offline
sounds normal for a 240
Originally Posted by iVteC_PoWeR
to me when i really look at it hondas just too expensive and theres not much power even after you spend loads of money...
http://www.cardomain.com/id/dbo240
***LOOKING FOR A COUPE, ENGINE IS NOT AN ISSUE***
Old 07-24-2005, 07:11 PM
Chuki_breath Chuki_breath is offline
Re: Re: Looked at a 95 today...
lol yep....except for the shock.....your getting coils anyway right??? lol
the tick is very common...all 3 here do it. Easy fix if you want to do it.
1993 base model 240sx coupe......to much to list. Just take a look at the link, 10 pages of goods.
http://community.webshots.com/user/nismosilvia240
Old 07-24-2005, 09:37 PM
well it has a set of kyb agx's...
Old 07-24-2005, 11:28 PM
D-Bo's Avatar
something could be loose in the right rear. its always tough to diagnose a shock unless it has lost all compression. a popular combination with the agx's is eibach springs. there are two drop possibilities you have with eibach. check it out on the eibach website, they explain it just fine there. if you want to keep your clearance the same then thats also cool.
about the shock, maybe check how old it is cause it might still be under warranty if you actually need to replace it. best thing to do is have a mechanic tell you if its a bad thumping noise or if its something you shouldn't have to worry about
