Old 07-24-2005, 03:21 PM
green96taurus green96taurus is offline
Cam shaft positioning sensor
Need a special tool to position cam shaft sensor? anyone have one or know where to find one?
Old 07-24-2005, 05:50 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Cam shaft positioning sensor
You can do the job without one. Remove the sensor, mark the syncronizer in 2 places on the engine and the syncronizer. Mark new syncronizer in the same 2 places. Install syncronizer till the 2 marks on motor and syncronizer line up. Bolt down and install sensor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-25-2005, 02:00 PM
TomV TomV is offline
Cool A bit of extra detail
Do a search for 'Cam Sensor Taurus' on this forum. You will see a post answered by me to a post specifically titled 'Cam Sensor on 97 Taurus'. The specifics are in that response.
I hope that your synchronizer vane is not too damaged or you will not be able to replace it as easily as this procedure describes. My procedure works if you can record the position of the rotating vane relative to various slots on the assembly.
Old 07-28-2005, 10:52 AM
wafrederick wafrederick is offline
Banned
Yes, you need that tool to set the synchronizer.You might have to try a Mac,Snap On tool dealer for the tool to set it and it is not cheap.My father has one and he paid about $85.00 for it.If you do not use the special tool,it will not run right
Old 07-28-2005, 11:32 AM
Cool
The special tool is required only if you are unable to record the position of the rotating vane on the shaft relative to the synchronizer body. The method I offer is the one I used for my repair.
The tool is used to line up the vane relative to notches in the synchronizer body when cylinder #1 is at TDC. This method is employed when no previous synchronization has taken place (at the factory or after engine disassembly) or has been lost (removing the synch assy without recording its position information or turning the crankshaft after removing the synchronizer assembly). The method I used is independent of the position of the #1 cylinder, as long as you can record the vane position prior to removal and do not change the crank position during the repair.
Old 07-30-2005, 06:12 PM
Vanagonfreak Vanagonfreak is offline
I have what you need - and you definitely need it to make the job easy and accurate. First, remove the cam sensor relay( the gizmo on top of the sensor with all the wires) and see if the vanes are intact. If not, you CAN change it out w/o too much trouble, but you have to move the plug wire and wiring harnesses out of the way. Biggest thing is, make absolutely certain you have the crankshaft at TDC #1 before doing anything. Also, the setting in my service manual required 38 deg. offset, thus the need for the tool. I repaired the engine myself, and I had to do ALL of that when my '96 blew the headgaskets and stripped the synchronizer vane(don't ask me how all that happened - no one knows). The car runs fine, now, so get in touch - I can make you a deal.
-Ted
Old 07-30-2005, 10:21 PM
Cool
If it is only the Sensor that is bad then the effort is something a normal home mechanic can do, provding you have a very small (5 mm or so) socket to remove the two screws holding it to the Synchronizer. The unit is located under the throttle cable assembly on top of the engine, beneath a pain in the ass plastic wire harness. I had to break the plastic harness to get to the Sensor. However it is an easy component to remove and replace once the components over it are removed.
That is the easy part. If the damage also includes the Sychronizer then more money is involved since it cost me around $160 from Ford. I have performed this repair myself and was able to do it in an easier fashion than indicated in both Ford and Haynes manuals. However this was because the vane in the Synchronizer was intact (though deformed) and I could determine its position relative to holes in the assembly and transfer that information to the replacement unit. This avoids the complex alignment procedure necessary when the previous alignment position is not known. You will not know if the Synchronizer is bad unless you remove the Sensor and perform a visual inspection.
The Haynes manual, available at your typical auto parts store, shows the assembly is located on top of the engine, underneath the spark plug wires 1,2 and 3, that are routed to the rear of the engine. You need to take off a few parts, such as an air hose, some electrical connectors, throttle cable assembly, plug wire routing harness and such. It is not too time consuming once you see the book and the sensor's location. You need the proper size wrenches. There is a flat, rectangular, plastic wire harness directly over the sensor that does not come off. I bent it around a bit and it cracked some, but not enough to cause any real damage. It does allow the overhead access needed to remove the plastic sensor from its housing. You need some small socket wrenches for this. I just bought a set of small sockets, metric and English, for stuff like this. An extension shaft of at least 6 inches is very useful here.
Once the sensor is removed (2 screws and electrical connector) you can view the rotating shaft in the synchronizer housing to determine the condition of the semicircle vane that rotates through the magnetic field of the sensor. Check the sensor for damage too. The magnet in the center of mine was snapped off and caused the vane to be bent inwards. If you do not see any damage to the metal within the housing then just replace the plastic sensor and see if that solves your engine light problem. Blow out any loose parts before assembly. If there is noticable damage to the metal within the housing then you need a new synchronizer. I paid about $30-35 for the plastic sensor (Autozone) and $159 (Ford dealership) for the metal synchronizer assembly. But I paid no labor. The job takes about an hour if only the plastic sensor is bad and about 2 hours if the synchronizer is faulty and you use the following procedure to properly align the system. It may also give you an excuse to buy some small socket and box wrenches as well! If replacing only the sensor does not eliminate the engine light then you could have a faulty synchronizer (gear not meshing properly) or an electrical problem between the sensor and the computer.
The tool used synchronize the system in the fashion described in the Haynes and Ford documentation (I have a copy of each) assumes that the #1 cylinder is at TDC. It aligns the vane of the rotating shaft relative to the magnetic circuit of the CMP Sensor. The vane disrupts the magnetic field as it rotates and the signal is sent to the computer. The 38 degree setting of the housing is not necessary for the synchronizing aspect but for assuring the electrical connector can be placed on the sensor since it is a fairly short cable.
The rotating shaft can fit in any one of 14 positions (14 teeth on the gear). It does not fit only one way, and is not polarized. I was also able to place the assembly in more than two different positions myself. Therefore, if you want to replace this assembly without the use of the tool and the setting of the #1 cylinder to TDC as described by Ford, you must record the position of the shaft's vane prior to its removal, relative to the housing. This is similar to using the synchronizing tool, but with the postion of the cylinders in an intermediate state.
After taking the plastic CMP sensor off, I transferred the position of the vane onto the top surface of the housing rim with a Sharpie fine tipped pen. The vane was bent out of shape from the magnet that fell from the sensor, but the edges were still in place. I then transferred a mark to the manifold across from one of the three small gaps in the housing rim, the one opposite the large gap for the electrical connector. This would ensure that housing is placed back to its original position and there would be no problem getting the electrical connector back on.
The entire assembly is removed with the removal of the single screw on the engine block. The shaft rotates CCW on removal.
Transfer the marks on the old assembly onto the replacement assembly. Oil the shaft thoroughly. Place the unit into the engine, inserting the shaft onto a pin in the engine. The vane should be rotated CW as it is pushed down. Once the assembly is against the engine, check the alignment marks for the vane/housing and housing/manifold. If necessary, pull up the unit and reinsert it in another position until the alignment marks correct. Now you can replace the hold-down screw and its fork/washer to keep the housing in place.
Old 08-11-2005, 02:28 AM
wesner1 wesner1 is offline
Had same problem on mine as well... only more fun. Let it go too long, piece broke off the dang thing and dropped down into the part underneath. Very expensive, very frustrating! Fix ASAP!
