Old 07-24-2005, 03:27 PM
phidelt phidelt is offline
Trying to Install the stock radio
I had taken out my dvd player and I am putting the stock one back in where would i get the harness to put back into the monsoon radio to hook up the speakers or are there any other suggestions to do this. the radio is powered and in the spot but the speakers are not hooked up the harness that was in the dvd doesn't fit so i assume i have to get a new harness? if someone could help out/clarify that woudl be awesome.
Old 07-24-2005, 04:15 PM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Trying to Install the stock radio
Ok if it is monsoon that you probably have a factory amp. which means they probably had to run a bypass for the speaker to work. what you probably need to do is try to find the amp. I think that it is located under the passenger seat. You need to disconnect the bypass and hook the speakers back into the amp and it should work
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
