'92 3000gt tt 4 $2500 need ur help
as the title says there is one where i live but this is also on the sign
stuff that needs fixing: 1.bottom end needs rebuilding 2.carrier bearrings for the propellant shaft 3.outer tie rod ends 4.lower ball joints 5.vavle stem seal replace 6.thrid gear synchornizer here r my q's. i know nothing about 3000gt's so what type of engine does it have? size of turbos? stock hp & trq numbers? max hp and trq on stock internals and turbos? is it fwd rwd or awd? how much am i looking at to fix these problems? thanx to any1 who can help me out |
Re: '92 3000gt tt 4 $2500 need ur help
one thing i forgot 2 mention is that the sign also said that the engine knocks? dont know what that means
go to www.cars.com or www.autotrader.com and do some research.
and if you must come back here, read the FAQ, as all that information is in there.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
oh yeah and if you don't know what an engine knocking is, then you probably shouldn't be looking to rebuild an engine. Because if you can't do it yourself, it will cost you more than just buying a new engine.
You should probably stay away from this car or try to get it for less. I believe this car was only AWD.
1987 Honda Accord LX-Dead 1999 Honda Accord EX-L 5 sp-Sold 2006 Subaru WRX Wagon 5sp-Sold 2005 Nissan Frontier ext cab 4x4 4.0L-Sold 2006 Kawasaki Ninja 500r-Sold 2004 Yamaha FZ1 Silver/Black- Sold ![]() 2008 Mazdaspeed 3-In the driveway |
Um 99% of what you asked is answered in teh FAQ. So read that, because few people will waste the time answering them.
As far as that car, judging by the questions you asked, it probably wouldn't be a good choice. It sounds like it needs too much work. Lastly, knock is pre-detonation.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Unless your extremely mechanically inclined (ie., can do all the work yourself) i would avoid that one. To have it fixed by a professional, your looking at probably $10000...it which case, you can find one in exellent shape instead. One thing about the VR4 and Stealth TT is that, though parts are expensive, the labor cost is what will really hurt you.
Mitsubishi advertised about 300hp stock and 325lbs of torque if memory serves...but that can be increased significantly (500+) by a few fairly easy mods. Not sure what size the turbos are, but it runs 14psi stock. 0-60 is under 6 sec and top speed is electronically limited to 155mph. Ive heard a few boasts that it will do 175 with a new comp. though... BTW, its a 3.0 liter TwinTurbo V6, AWD other possible options: AWS Active Exhaust Active Aero Active Electronically Controlled Suspension (ECS) a few good sited for more info: www.3sxperformance.com www.3si.org www.vr4stealth.com |
top speed isn't electronically governed at 155, it's drag limited at ~160.
