Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 07-24-2005, 11:34 AM
pullhook pullhook is offline
O2 Sensor
My 97 Astro AWD V6 failed the e-check OBD-II test. It showed a A0420 code so I replaced the Converter. The Check Engine Light came back on the next day, when I checked it showed a P0137 code(O2 circuit low voltage, Bank 1 Sensor 2) so I replaced the Oxygen sensor behind the converter. The light came back on the next day and shows the same P0137 code. Which of the 3 sensors is it refering to when it shows (Bank 1 Sensor 2)? There is a sensor just below the manifoldand' 1 in front of and 1 behind the converter, did I change the wrong sensor? Any suggestions?
Old 06-05-2006, 01:34 PM
matthew46 matthew46 is offline
Re: O2 Sensor
SHould be the one in front of the cat.
Old 06-05-2006, 01:36 PM
Re: O2 Sensor
Oops, I meant the one behind the cat. Sensor 1 is in front. Check your battery ground.
Old 06-05-2006, 06:49 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: O2 Sensor
Bank 1 is on no one cylinder side. sensor 2 is second sensor back
It should be in front of cat sensor 3 would be behind cat.
But many things beside the sensor can cause a code.
Get a repair flow chart for it and go threw the flow chart.
Did you use oem type sensor or splice in type?
MT
MT
