Old 07-24-2005, 09:51 AM
twmagoo twmagoo is offline
2002 taurus AC blower
Only in the mornings once I start up my car the ac blower doesn't work.
I have tried looking at the relays under the dash and at the fuse block under the hood...just as I was ready to give up and decided to get me some relays from the store...that ac blower starts to blow after I shut the hood. The next morning samething, I tapped on everything thinking that maybe a relay is sticking but nothing worked until I shut the hood.
Heres some facts ;
The AC compressor is on and freon is being pumped, still blower not working.
AC compressor isn't kicking off and on to indicate low freon
Once the blower starts working...it works all day until it sits up over night.
Hope thats all I need to relay for info, ty in advance.
Old 07-24-2005, 02:08 PM
iamsodamnconfused iamsodamnconfused is offline
Re: 2002 taurus AC blower
Hey, I had the same problem in my Taurus. Replace the blower.
Old 07-24-2005, 05:40 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Wiggle the connection on the blower when it is not working. If it starts to work, then the connector is loose or one of the pins is loose inside the motor. You can tighten the connections with a small screwdriver by inserting into the end of connector between the flat side od pin and the housing. Slightly twist screwdriver to barely bend the flat side of the pin connector. If it is internal, replace the motor.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
