Old 07-24-2005, 08:15 AM
newfdude newfdude is offline
Unhappy carb problem
i have a rochester carb 4barell i cleaned it good but it wont idle right only if its above 12oo rpm if its below its stalls it drives good but when i come to the stop lights she starts to act up shakes idles bad any help please thanks
Old 07-25-2005, 12:24 PM
MrPbody MrPbody is offline
AF -Advisor
Re: carb problem
Which Rochester? Q-Jet? Did you replace the float? Is the throttle shaft sloppy?
Old 01-11-2006, 05:09 PM
ramairgto72
Guest
Posts: n/a
Re: carb problem
So many things can be causeing this problem, before you take apart your carb, make sure you not leaking any air from anyplace, make sure the gasket under your carb is not sucking air under it, but don't over tighten the bolts, they will strip, try getting a good thick gasket for the carb to intake seal.
As I said so many things can be wrong, from bad floats to a stuck choke..
You best bet is to buy a book on your carb at your local auto parts store, you can learn your carb and help others, and maybe make some money rebuilding them.
So may Carb shops have gone under, it's to bad, so many people need carb help.
I have a 650 EDL. that I opened up and polished it, I have the rebuild kit, and plan to take pictures and put it on my web page.
Old 01-15-2006, 03:10 PM
cowood cowood is offline
Smile Re: carb problem
Take Your Quadrabogger And Use It For Target Practice . Go Buy A New Holley Or Edle Brock. No Quicker , Easier Fix Than A New Carb, Plus Their A Whole Lot Easier To Tune. Look Good Last Long Time.
