Old 07-24-2005, 07:48 AM
fritcr's Avatar
fritcr fritcr is offline
96 escort wagon no power
My wagon has a 1.9 auto and it sometimes has a fit has no very little power. When this happens my fuel milage goes way down and my transmission shifts very hard. Esp from first to second. Does anyone have any ideas on this. Sometimes it runs fine...tranny shifts fine too. Other times...it just has not power. It does not miss and I can drive it but it takes forever to get it up to cruising speed on the hwy. Any help would be great.
Rob
Old 07-24-2005, 08:39 AM
hytwr1 hytwr1 is offline
I'm having similar problems with a 96 1.9L wagon. The problem was worse with the a/c on. I checked and then changed the EGR valve and that helped. It was sticking. You might look at that.
However, mine still takes awhile to get up to speed and runs rough. If you crack the throttle open to about 1100rpm, it sputters constantly. I suspect dirty injectors are causing this as I can here them fire, using the screwdriver stethoscope method, but one is not firing as loud as the rest.
I'm curious to see what you come up with.
Bill
Old 07-24-2005, 09:43 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
I was thinking EGR valve too but I believe it is supposed to be open when accelerating. This might be something as simple a a fuel filter. Next time it does this try removing the gas cap. See if there is a vacuum there. A clogged fuel tank vent can create a vacuum and starve the engine for fuel.
Nevada Tumbleweed
Old 07-24-2005, 01:23 PM
I've run into excess pressure at the fuel cap but not vacuum. Where's the vent?
Old 07-24-2005, 01:56 PM
It vents through the charcoal cannister in the engine compartment. Pressure could be a sign of a clogged vent too.
Nevada Tumbleweed
Old 07-24-2005, 03:09 PM
fritcr's Avatar
96 wagon with no power
There is no pressure or vaccum at the gas cap that I remember. Maybe a little but not much. It has a new fuel filter on it I'm pretty sure. I will check on that. Maybe the EGR could be the problem. I will have to look at it and see where the egr is at on it. Would any of this make my tranny shift hard when this is happening? It is very strange.
Rob
Old 07-24-2005, 04:08 PM
I'd guess the tranny is another problem.
Nevada Tumbleweed
Old 07-24-2005, 04:15 PM
If it's like mine, the EGR is located on the rear of the intake/plenum. It's near the throttle body.
I pulled and plugged the vacuum line off mine and the bulk of the problems went away. Then pulled the valve off and found it full of carbon. Cleaning it didn't seem to help the way it actuated. FYI, it's $60 part at NAPA.
Re: charcoal canister, roger that.
Bill
Old 07-25-2005, 12:37 PM
OK.
Looking at the evap emissions system, I find the canister and the canister purge solenoid. The solenoid makes a clicking sounds when the throttle is cracked open. Is this normal?
Old 07-25-2005, 02:55 PM
fritcr's Avatar
Re: 96 escort wagon no power
I will try to check out that egr tonight when I get home. So if I plug the vac line it might kind of tell me if that is the prob or not? I have no check light by way either. I forgot to tell you that.
Rob
Old 07-25-2005, 03:42 PM
Escort_Service Escort_Service is offline
I had a simular problem and I had to replace the throttle position sensor. Not quite sure how that happened but it worked.
5.0 Mustang where would you be if I took 4 of your cylinders? In the scrap yard you ugly piece of #$?@
Old 07-25-2005, 03:47 PM
There was no check engine light on mine either. I was just going on experience and the symptoms. I was getting hesitation, rough running and poor performance. I had a Ford mechanic describe the EGR symptom like a horse bucking while under load.
If you plug the vac line and the engine smooths out you know there is a problem with the EGR. In my case it would open, but not in a nice easy motion. I took it off and using my mouth, inhaled on the vacuum connector. It would pop vs moving slowly. This tells me it was probably sticking when closing too. I tested the new one the same way and it opened slowly, but consistently. The idle is better and there is no hesitation/dead spot like before.
It still doesn't have the power it should though.
Old 07-27-2005, 07:08 PM
fritcr's Avatar
96 Escort Wagon 1.9l auto
I am messing with my Racecort as we all call it and I plugged off the vac line to the EGR valve but it really makes no difference. Bad thing is...this is one of it's good days and it has been running perfect all day for me. The weather here cooled off about 30 degrees overnight so I don't know if it has something to do with it being reall hot out or what. We have had temps over 100 for several weeks until today and it is 78 out. Anyway, my wife is picking up a fuel filter just in case that might be it. I tried to take the throttle position sensor off and I was going to try to test it with my ohm meter but I can't get the philips screw out of it so I gave up. With the car off (of course) I unpluged the egr vac line and plugged a new on on and sucked on it and I can hear it moving and sort of makes a pop sound. It will hold vac to it also. It amost always idles fine but it is accelorating and going down the hwy when you notice the fits it has. Sometimes it will sort of buck a bit going up a hill with the a/c on. BUT only when it is having a bad day. It has been having a lot of them lately. Any other ideas. I will put the fuel filter on when my wife gets home in a few. Maybe that will help it. I hate to put much more $$'s in it because I'm selling to my bro in law. I want to know it is running ok though so he don't have trouble with it. I bought a Malibu. I will probably regret it after looking at some of the posts there.
Rob
Old 07-27-2005, 07:12 PM
Dude Ive heard that people have had that same problem and it turned out to be there feul pump.
Old 07-28-2005, 07:45 AM
fritcr's Avatar
Oh man I hope it is not the fuel pump. That would cost me more than I paid for the car!
Rob
PS.. ran fine on the way to work again...and wifey forgot the filter last night.
