Old 07-24-2005, 03:39 AM
talontsi26 talontsi26 is offline
slow POS car!!!!!!!!
Can somebody explain to me why it seems like my car gets slower with every upgrade? When I first purchased my car it had a 2.5 downpipe, cat and exhaust, kn filter; with this setup I ran a 13.9 1/4 mile. Then I installed a 2.5 testpipe, balance shaft eliminator kit, rewire kit for the fuel pump, and a mbc set at 15 psi, with these upgrades I clocked a best time of 14.2, which means i got SLOWER!!!!! So i installed a 190 fuel pump and an evoIII 16g, now my best time is 14.6.....what the heck is going on???????
Old 07-24-2005, 03:54 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
You need to do some tuning with your new setup.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-24-2005, 03:55 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: slow POS car!!!!!!!!
Is your mph getting higher or lower? ET means you suck as a driver... mph won't lie.
cficare68's Avatar
cficare68 cficare68 is offline
Have you had it tuned??????
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 07-25-2005, 02:13 PM
mph is getting slower!!!!
Old 07-25-2005, 07:58 PM
MoozillaGSX's Avatar
MoozillaGSX MoozillaGSX is offline
Send a message via AIM to MoozillaGSX Send a message via Yahoo to MoozillaGSX
just a question of my own, but would it have to do with his bigger turbo setup and a 2.5 inch Exhast ? wouldnt it flow betetr with a 3" ?? could that be A problem. ?
Austin - 95 GSX .
-K&N FIPK.
-Ijnen UICP + Greddy RS BOV.
-Rota Slipstream + yokohoma Es100's.
-Tokico HP Blue's + Springs.
-Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads.
-Manacore Wires.
( got a 20g and the works in the clothset )
Old 07-25-2005, 11:30 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
evo 3 should still be faster then a 14b even with a 2.5 exhaust.
it probably needs a good tune, maybe a tuneup and then you need to practice youre driving. are your reaction times staying the same? did you drive it and get a 13.9 or was that the guy you bought it from driving? have you checked for boost leaks and everything?
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-26-2005, 02:33 AM
I was driving when i got the 13.9!!! When I have the gas pedal to the floor it feels as though the power just isn't there anymore. I can hear the turbo spool up very loudly but my rpm just isn't rising all that fast.
Old 07-26-2005, 02:40 AM
We already told you what the problem was. You need to tune the damn car. You can't just throw on a bigger turbo and expect it to magically run 12's.
You also need to check for boost leaks, get an aftermarket boost guage so you can accurately tell exactly how much boost you are doing, and probably upgrade your injectors to compensate for the increased airflow.
'92 3000gt SL
Zoom Stage 1 Clutch
