Old 07-24-2005, 12:31 AM
tomjanovich tomjanovich is offline
Unhappy 96 taurus overheating problem
Ok, here is my problem
My girlfriends car is having a problem with overheating. it doesnt ever fully overheat, it seems that the fans are not engauging when they should be. it will start to get hot, then all the sudden when the needle gets near the top, it will shoot straight down again like the fans allt he sudden kick on.
so far ive replaced the thermostat, flushed the coolant checked for leaks and loose wires.
Im not all that good with electrical, so im confused. the next thing im going to try is the temp sensor and the fan connections or soemthing.
anyone have any suggestions.
thanks for any help
Joe
Old 07-24-2005, 01:06 AM
KimMG KimMG is offline
AF - Advisor
Re: 96 taurus overheating problem
Sounds like you are on the right track.
Old 07-24-2005, 12:49 PM
pdowg881 pdowg881 is offline
oil
Old 07-25-2005, 09:10 AM
oil?
I dont see how oil is the culprit.
its been changed regularily
thnaks kim
Joe
Old 07-25-2005, 10:50 PM
AF - Advisor
Low oil level or if you are over due for a oil change (contaminated, dirty) can cause the motor to run hot.
Old 07-25-2005, 11:37 PM
oh ok,
no, I change the oil often.
thanks
Old 07-26-2005, 12:02 PM
Willyum Willyum is offline
You check the flow of the radiator? I had been using my local tap water mix when I changed coolant and the mineral deposits obstructed the core in 2 years. They can't be flushed out, had to replace the radiator.
Old 07-27-2005, 08:22 AM
joe92k1500's Avatar
joe92k1500 joe92k1500 is offline
Asuming the temp guage is correct, when it shoots down all of a sudden, its usually air in the system or not enough pressure. you may want to try replacing the cap on the coolant tank. This may be worn and not allowing the system to get to the correct system pressure.
Old 07-29-2005, 12:11 AM
Thanks, Ill try that stuff.
Joe
