Old 07-23-2005, 10:38 PM
hytwr1 hytwr1 is offline
fuel injector cleaning
I've seen several folks here refer to how they cleaned their fuel injectors. How did you clean them? By that I mean what are you using?
I've tried looking at Autozone and Advance for the type of injector cleaner that is run directly through the fuel rail and nobody seems to know what I'm looking for.
What's the secret?
Thanks
Old 07-24-2005, 05:19 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Gasoline has detergents in it so I've always figured you should't need to have the injectors cleaned. The type of injector cleaning you are referring to is done at diesel engine shops but I don't know if it's the same as for gas engines.
Nevada Tumbleweed
Old 07-24-2005, 01:26 PM
There used to be fuel injector cleaning kits available that used aerosol cans attached to a hose that connected to the fuel rail. I think this is what I'm looking for.
Old 07-25-2005, 03:39 PM
Escort_Service Escort_Service is offline
Re: fuel injector cleaning
dont bother. The injectors on the escort are built to last forever. Running the stuff you put in your gas can will should be good enough.
5.0 Mustang where would you be if I took 4 of your cylinders? In the scrap yard you ugly piece of #$?@
