Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-23-2005, 07:42 PM
pimpcrx_kid pimpcrx_kid is offline
Send a message via AIM to pimpcrx_kid Send a message via Yahoo to pimpcrx_kid
crx smoke?
ok i had a mint crx DX for sum reason it had a lsd tranny,n it was fast as hell,im not sure wut was done to it b4 me but it was a quik car, like i smoked crx si's all the time anyway i sold my car to my cuzzin n he beat it pretty bad he did front words donuts on the tar n stuff like that,yes front n yes i no its a front wheel drive car,newayz it started smokin when ud get into it so he added oil additave but becuz hes a stoner he added the aditive while his car was full of oil so i checked it once n it was like 2 quarts over...anyways now the car blows alot of blue smoke but still has plenty of power would it be bad rings or bad head gasket??
Old 07-25-2005, 06:08 PM
Privatebigandrew's Avatar
Privatebigandrew Privatebigandrew is offline
Send a message via AIM to Privatebigandrew Send a message via Yahoo to Privatebigandrew
Re: crx smoke?
maybez itz de motor gettin madz at all da slang yall bez uzing. I know my engine wouldn't take dat shiznit yo. Maybe youz should talk straight fo sho and you could get sum serious respones yo. And keep up the tihgt front burnoutz yo, damn that shit is phat as phuck. Could beez from all dat oil in der man. I mean hellz, any engine would smoke like a newport if it was 2 quarts over yo. Drain that shiznit and put the proper amount in it. If its still smokin you need some 24K rings up in there man, that'll seal it up with the tightness. (I hope you can get the seriousness through all the slang)
94' Del Sol VTEC (B16A3) SOLD.
Accel plug wires, NGK iridium IX plugs, AEM short ram intake, DC sports ceramic coated header (4-2-1), Airmass high flow cat ,Custom Magnaflow exhaust, Bosal Brospeed tips, Neuspeed short throw shifter, Tokico clutch master cylinder, Tokico clutch slave cylinder, Prothane complete kit bushings, Brembo front rotors, NR EL-Glo instrument gauges, CTR LSD trans with ITR final drive, Exedy chromoly flywheel, ACT HDSS clutch kit, Raxle axles.
Old 07-25-2005, 06:17 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: crx smoke?
i say rings, or headgasket... but either way, you need to take the head off to do rings so you need to replace the headgasket anyway.
